Staggered setup on AWD ! - The Mother Thread - !
Old 09-11-09, 06:17 PM
mdgrwl
mdgrwl's Avatar
Exclamation Staggered setup on AWD ! - The Mother Thread - !
I want to open this thread where PEOPLE WHO ARE ACTUALLY RUNNING THIS SETUP (Staggered on your IS250awd) post here -
Please post on these topics:
- What is your exact wheel/tire setup ?
- How many miles you've been running this for ?
- Are you noticing any issues (gas millage ect...)
- Also post your general thoughts/comments
Again, people who are actually running this setup - or - people that are well educated on the topic - please post here so we can have a dedicated thread for this highly debated topic.
Old 09-12-09, 06:29 AM
Likwid XTC
Likwid XTC's Avatar
volk gt av 19 x 8.5 n 9.5
tires dunlop sport maxx 225/35 n 235/35
off set 24 n 25 i be;ieve
10k plus miles
havent noticed any gas problem i guess when modding cars i dont pay attention to that stuff that closely anymore
ride qaulity is decent which i expect im cambered a little cause of the drop n offsets
none the less you look gangsta as **** if u keep your ride clean and cruising, i have them with kics r40 and ppl are just liek wtf
ill be running 19 x 9 n 10 with a 22 offset soon as im done being lazy and get them on
Old 09-12-09, 06:55 AM
as3.0cl
as3.0cl's Avatar
MRR HR2's
19x8.5 +35 up front with 235/35/19 exclaim UHP's
19x9.5 +39 in rear with 275/30/19 exclaim UHP's
rolling diameter is .1% difference which is virtually nothing
had the tires on since March. approximately 15,000 miles on them so far.
no issues what so ever concerning the awd system.
gas mileage is about the same, averaging currently with my commute about 24mpg 50/50 mix.
dropped on F-sports. front has a very minor rub and is pretty close to flush, and the rear is slightly tucked behind the fender by less then a finger.
Old 09-12-09, 08:32 AM
Rash
hmm
Rash's Avatar
Cathafer's setup should be posted here.
Old 09-12-09, 09:20 AM
javyLSU
2IS OG
javyLSU's Avatar
10k plus miles
^One of my favorite wheels.
Javier
Old 09-12-09, 09:32 AM
is2seattle
is2seattle's Avatar
F - 19x8.5 Face-1 35mm offset. Toyo Proxes T1-R 235/35/19
R - 19x9.5 Face-2 36mm offset. Toyo Proxes T1-R 265/30/19
Dropped on Eibach springs for IS350
10,000 miles
No problem so far... gas mileage is about the same
The wheels diameter is less than 1% difference so I don't think there would be any problem
Old 09-12-09, 02:24 PM
laobo979
laobo979's Avatar
-Running 19x9 235-35-19 and 19x9.5 265-30-19 with no rubbing at all dropped on BCR coilovers
-5K on them
-No issues at all
Old 09-12-09, 03:01 PM
mdgrwl
mdgrwl's Avatar
Great, so far looks like Staggered on AWD (slong as the tire diameters are close/identical) there's been no problems...
This is hardly definitive though. More post n' comments please.
Old 09-12-09, 06:36 PM
Likwid XTC
Likwid XTC's Avatar
like any setup it all depends on the personal users wants/setup
like fo r me i want wide and low off set and (future drop will be tucked i hope) low
so in doing so stretched tires come into play negativr camber shaved/rolled fenders
Old 09-12-09, 09:39 PM
autofreak
autofreak's Avatar
my auto teacher told me not to perform this setup as it causes many transmissions problems, but apparently everyone is driving fine huh
Old 09-12-09, 10:47 PM
slip969
slip969's Avatar
First off. Wonderful forum and it's full of very knowledgeable people.
Alright... so major question here to the users that are running this setup. I placed an order for staggered rims last night and I'm really hoping this will work.
Car: 06 IS250 AWD
Wheel Make & Model: TSW Snetterton
Wheel Size (diameter and width): 20x8.5 & 20x10
Wheel Offset Front: ? <-- Not sure. Whatever the default is.
Wheel Offset Rear: ?
Tire Front: 235/30ZR20 Kumho Ecsta SPT
Tire Rear: 275/30ZR20 Kumho Ecsta SPT
Suspension mods: H&R springs for the AWD 250
After some research after I placed the tire order from TireRack. I'm seeing that I'd have to drop the rear profile slightly to get the correct ratio. However, it's impossible to find lower profile then a 30 with reasonably priced tires. So obviously need to cancel this order and get the correct profile tires. Would a 35 instead of a 30 fit in the front without rubbing?
Really need some help .... If this is the wrong thread to discuss this... my apologies.
Quick Edit:
Looks like a 35 in the front and a 30 in the rear would be the perfect ratio. However... how bad would the rubbing be in the front on a 20 x 8.5 rim and 235/35/20 tires with the H&R drop?
Tire 1 - 235/35R20 >Search Tires Tire 2 - 275/30R20 >Search Tires
Section Width: - -
Section Width: 9.25 in 235 mm
Section Width: 10.82 in 275 mm
Rim Diameter: - -
Rim Diameter: 20 in 508 mm
Rim Width Range:
Rim Width Range: Unrecognized tire size.
Rim Width Range: 9.5 - 11 in
Overall Diameter: - -
Overall Diameter: 26.47 in 672.33 mm
Overall Diameter: 26.49 in 672.84 mm
Sidewall Height: - -
Sidewall Height: 3.23 in 82.042 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: - -
Radius: 13.23 in 336.04 mm
Radius: 13.24 in 336.29 mm
Circumference: - -
Circumference: 83.15 in 2112.0 mm
Circumference: 83.22 in 2113.7 mm
Revs per Mile: -
Revs per Mile: 785.7
Revs per Mile: 785.2
Old 09-13-09, 12:07 AM
DoTheDrew
DoTheDrew's Avatar
[QUOTE=is2seattle;4841002]
wow beautiful car.
Old 09-13-09, 08:36 AM
mdgrwl
mdgrwl's Avatar
Lets try to keep this thread on track. Users with experience running staggered on their AWD - please post.
Old 09-13-09, 08:39 AM
PaPaHoFF
PaPaHoFF's Avatar
10,000 miles
Sick car but even sicker background!!
mdgrwl
mdgrwl's Avatar
Car: 06 IS250 AWD
Quick Edit:
Section Width: - -
Rim Diameter: - -
Rim Width Range:
Radius: - -
Circumference: - -
Revs per Mile: -
Its just about impossible to run staggered 20's and keep the rolling diameter close without running something crazy like a 285/25/20 rear. If you could and its not too later, go for 19's. Much easier to get the diameters the same and not run monster truck tires in the rear.
Quick Reply: Staggered setup on AWD ! - The Mother Thread - !
