Old 12-16-14, 11:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
IS250 rear brake replacement (GREAT DIY with lots of PICS!)
Old 07-09-09, 12:15 PM
grandamliz
grandamliz's Avatar
Default IS250 rear brake replacement (GREAT DIY with lots of PICS!)
this is a just a guide line for you to use. do it at your own risk.
Size:  93.4 KBhere are some things you will need. 14mm deep socket and regular socket, needle nose pliers, flat head screw driver, brake cleaner, disc brake quiet, hammer, c clamp or a brake caliper tool, equipment to lift vehicle and remove wheel, and a m-8 1.25 screw.
this screw will be used to remove rotors.
start by lifting one side of vehicle first and remove wheel.
Size:  44.9 KB romove 14mm bolt, and a second 14mm bolt on the bottom side
now u can remove the whole brake caliper.
now with the caliper removed u can remove the brake pad slide pins retainer pins and brake pads
you will need the needle nose pliers to remove the retainer pins.
now that the those pins are removed the sliding pins will slide out
make sure u keep these pins and do not brake them or discard them
Size:  59.1 KB here are some other angles on how they go together for more reference.
now u will need the caliper tool or c clamp to push the piston back into place.
now with the piston back in place u can take this time to paint your caliper if so choose to. use a towel to cover up the inside of the piston and moving parts before you start to paint.
now with all that out of the way, now u will remove the disc by using that m-8 screw. thread that screw in and keep threading until the disc pops off. NOTE not all discs need to be poped off some will come right off after the caliper is removed.
now with the disc removed, if you are going to replace the disc remove the rubber groment from the old disc.
you will take this and place it on the new disc and put the new disc on. it should just slide on no screwing on or pressure needed to put the disc back on.
now with the disc on u will take some disc brake quiet and place some on the piston and inner walls of the caliper.
now you will bolt the caliper back on into place without the new pads in.
after you bolt it back on you will place the new outer pad in.
with the new pad a few love taps should get it to slide into place.
now that the pad is in u can slide the inner pad into place.
when you slide the pads in try keeping them lined up for the pins to slide in.
sorry not enough room to finish on this page. look for part 2.
Old 07-09-09, 12:28 PM
grandamliz
grandamliz's Avatar
Default is250 rear brake replacement part 2
part 2.
start with the retaining pin first.
when you get this pin in you can place the sliding pin in.
once you slide that pin in you now place the other pin in. when that pin is in place you will place the other retaining pin in.
once the pins are in place you are done with the caliper.
now go in your vehicle and press on the brake pedal and keep pumping untill its a firm feel.
i did this job myself in about 2 hours and i bought the the cross drilled slotted and vented discs and creamic pads from brake labs on ebay
if you have any questions feel free to ask and i will respond as soon as i can.
Old 07-09-09, 04:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Nice DIY! Thanks for the pics, it makes all the difference and I know it's a PITA to remember to shoot every detail. Good job!
You might want a part three to include adjusting the parking brake...
Old 07-09-09, 05:52 PM
mikez
mikez's Avatar
Awesome, thanks for the diy man.
Any pics of the brakes with the wheels back on?
Old 07-09-09, 07:16 PM
Hoovey689
Hoovey689's Avatar
Very detailed DIY. Well done!
Old 07-09-09, 07:27 PM
sinister2c
sinister2c's Avatar
this applies to the IS350 too since they use the same pads
Old 07-09-09, 08:13 PM
Phiber
Phiber's Avatar
Very nice DIY. You should give a review about the rotors. I am interested in them also. Also, which one did you buy?
I didn't know there is a jack point under the wheel. Mind explaining?
Old 07-09-09, 08:17 PM
Fizzboy7
Fizzboy7's Avatar
Is it safe to jack up your car on gravel!?
Old 07-09-09, 08:29 PM
Phiber
Phiber's Avatar
it should be fine, he has jack stands on the frame also..
Old 07-09-09, 09:45 PM
javyLSU
2IS OG
javyLSU's Avatar
I think you just made the greatest 1st and 2nd posts in the history of teh interweb.
Great job, thanks for sharing!
Javier
Old 07-10-09, 06:58 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
thanks for sharing...
Old 07-10-09, 11:51 AM
blk250
blk250's Avatar
very very details...
Old 07-10-09, 02:12 PM
gs400998
gs400998's Avatar
Great Job!!!!
Old 07-11-09, 03:33 AM
Sgt_K
Sgt_K's Avatar
Guys, jacking a car on gravel is a bad idea, also jack stands should be used, its not fun to drop a car on the ground because of a faulty jack.
Also, if you don't need to replace the rotors, you can just pull the spring clips and use a big screw driver to push in the piston.
Old 07-11-09, 03:52 AM
Kevin.IS
Kevin.IS's Avatar
Nice DIY thanks for all your hardwork!
Quick Reply: IS250 rear brake replacement (GREAT DIY with lots of PICS!)
