FL Sc400 m112 supercharger kit, fuel , electroincs $2800 shipped
Old Jul 5, 2009 | 11:57 AM
twizted's Avatar
twizted
Default Sc400 m112 supercharger kit, fuel , electroincs $2800 shipped
I am selling my car, I need a truck . So I cant finish this project. Its ready to go you will just need to do the tuning. Your looking at 100+ hp gain depending on boost but cant give you numbers cuz i have never run it. Tuner tells me engine is good for 15psi with decompressing with larger head gasket. So here it is
1.
I'm sure you know this is a rare opportunity if your looking. This is just as I got it from lextreme. Selling because I am going to be needing a truck here within a year, have no time to install and take to tuner and i cant really drive fast where i am lots of old people. The M112 has been modified to fit under the hood. It has has a 6 rib billet modular pulley along with a throttle body adapter. The charger mounted and aligned and a proper sized belt also come with it too.
The Richwood Manifold also modded to host an extra injector and I can also throw in a 1,600 cc injector. This combo also include a Split Second Extra Injectors Control. You can just run the 315cc injectors whichever you like and sell the other fuel setup.
This is what you get:
* Richwood Root Supercharger Manifold
* Modified M112 Supercharger
* 6 ribs modular pulley by Billetflow 2.9 and 2.7 estimated to be 12 and 10psi
* 315cc injectors ultrasonic cleaned and flow test matched
* aem fic piggyback ecu my dyno guys swears by this and the zt2 are the best matchup
* zeitronix zt-2 lcd monitoring system with wide band, egt sensor and map sensor which can all be run together with the aem
* Custom Throttle Body
* Custom Extra Injector bung (mounted and welded)
* 1600 cc extra injector
* Split Second Extra Injector Computer
* Two idler pulleys
* Custom Serpentine belt
Things You need to do:
* Mount the throttle cables
* Block EGR
*Get rising rate FPR
This system is pretty much ready to bolt with minimum work. I am asking $2800 shipped
You will be able to run up to 15psi all day on this package, install and tune will be needed for the electronics on a dyno...
Please see this page for more details http://www.lextreme.com/Supercharged-Lexus.html other updates in here http://lextreme.com/forums/showthrea...highlight=m112
Please pm if you are interested.
Note: The alternator is not mounted properly so the belt looks little loose. This system will from for SC400 from 1992 to 1997 and LS400 from 1990 to 1997 along with other international models with similar year.
Old Jul 18, 2009 | 01:17 PM
Dark_Eric's Avatar
Dark_Eric
Sounds pretty good. Is this already sold? So this gives 100 HP gains at 15 PSI? I'm only looking for an additional 50-75HP but this looks like it will do. I can do probably $2500 shipped, but I also need a good shop in NY or NJ that can put it on and I want to do other upgrades on my '98 Firebird. Is this still available?
Old Jul 18, 2009 | 03:08 PM
twizted's Avatar
twizted
Well at 15psi i would estimate that or more i cant say for sure. Again haven't run it, lextreme just fabed it all up and fitted it. I got the rest of the parst to run it, I wont take less then the $2800 shipped i spent $4300 on the set up to date. I have a couple people that are saying there coming up with the cash. Whoever can do it first get it....
Old Jul 22, 2009 | 04:38 PM
twizted's Avatar
twizted
Still available
Old Aug 3, 2009 | 07:09 PM
twizted's Avatar
twizted
bump.....................
Old Aug 6, 2009 | 09:08 PM
twizted's Avatar
twizted
Still available guys im dropping it ill take $2600 shipped!
Old Aug 8, 2009 | 06:03 PM
twizted's Avatar
twizted
SOLD* please lock
mtnrat
SC400 / 300 Classifieds
17
Oct 27, 2012 02:20 PM
twizted
15
Jul 9, 2009 11:36 AM
twizted
15
Dec 29, 2008 11:01 AM
twizted
Oct 11, 2008 12:37 PM
twizted
13
Sep 21, 2008 02:58 PM
