wiring diagram help
Old Jul 21, 2007 | 01:54 PM
Giggzz's Avatar
Giggzz
Default wiring diagram help
Good day all, I was hoping some one with experience with wiring diagrams could help me out.
Im swapping out my standard 99 GS400 radio for a standard 2003 GS430 radio. I have some questions on the diagram that I have highlited in red.
R3 is the plug type and the # next to (B) is the pin #.
!) what does it mean when you have 20(B) over 2(A) as highlighted in red?
2) with the (*5) Except Taiwan and (*6)Taiwan do you still use that pin or remove it? Theres a section at TX+, BUS+ TX-,BUS-, not sure if the wiring is to be connected or not.
Im sure I'll have a few more questions as I try to figure this out.
Thanks!
Old Jul 21, 2007 | 07:10 PM
diamondmit's Avatar
diamondmit
Default Are the letter designations referring to wiring busses? I notice that....
there are multiple designations (A, B, C, D...etc). These might be pin locations on bus A, pin locations on bus B, etc. You can probably verify this by looking at how the existing radio is connected. If this is the case, 20B and 2A may share a connection.
Hope this helps!
dd
Old Jul 21, 2007 | 11:44 PM
DrexLex's Avatar
DrexLex
Originally Posted by Giggzz
1) what does it mean when you have 20(B) over 2(A) as highlighted in red?
Assuming your 2003 radio was not sold in Taiwan, then you ignore the pins near Note 6. The pinouts near Note 5 are the ones in effect.
There's a section at TX+, BUS+ TX-,BUS-, not sure if the wiring is to be connected or not.
In my understanding, TX+/- is the CAN bus, so I'm not sure why they are splitting hairs over the nomenclature, since they appear to do the same function whether case 5 or 6. In any case, you need to connect the amplifier's bus lines to the radio or else you will lose volume control and various other amp functions.
Old Jul 22, 2007 | 09:29 AM
Giggzz's Avatar
Giggzz
Here is a picture of wiring diagram fo the 99GS400 there are two pictures
Old Jul 22, 2007 | 09:30 AM
Giggzz's Avatar
Giggzz
Here is the second for the 99GS400
Old Jul 22, 2007 | 09:50 AM
Giggzz's Avatar
Giggzz
Here is the picture for the 2003 GS430
Old Jul 22, 2007 | 09:51 AM
Giggzz's Avatar
Giggzz
Here is the second picture for the 2003GS430
Old Jul 22, 2007 | 09:56 AM
Giggzz's Avatar
Giggzz
Here is a picture of the plugs and how I see the wiring to each pin go. Can someone please confirm what I have done is correct?
The one problem Im having is on pin 3(B) on the 99 GS400 picture I can not see where to run that wire to the 430 diagram.
My first time trying this so before I go pluging in wires need some professional help.
Old Jul 22, 2007 | 02:06 PM
DrexLex's Avatar
DrexLex
I'm sorry, I cannot follow the drawing, but first let's make sure you have the right connections from the 2003 radio going to the 99 amp. My best guess is as shown. Does it agree with your understanding? If so, is that what your connections are doing?
Old Jul 23, 2007 | 06:58 PM
Giggzz's Avatar
Giggzz
A few questions from the attached drawing:
See #1 - where does that lead to?
See #2 - where does that lead to?
See #3 - Where does the ground lead to?
See #4 - Can the ACC here connect at #1?
What does it mean when you have this: Example
Mute
7(B)
8(B)
Do the wires from pin 7(B) and 8(B) get spliced together than connected to 4(A)mute?
Thanks
Old Jul 24, 2007 | 04:25 PM
DrexLex's Avatar
DrexLex
Mute
7(B)
8(B)
Thanks
Connect ACC #1 to #4. This is how the radio tells the amp to turn on.
#2 is B+, so that connects direct to the battery. Same as pin4 of the 99 amp.
#3 is the ground (battery negative, or chassis) lead. Same as pin 7 of the 99 amp.
Mute 7(B) 8(B). Remember there are two sets of pinouts, one for TW, the other for everywhere else. You use “7(B)” and ignore the other, as if it was not on the diagram at all. This is true for all these “double pin” cases. Connect 7(B) to 4(A).
By the way, I am not guaranteeing your transplant will work—I’m just helping you understand the diagrams. I hope…
Old Jul 24, 2007 | 06:21 PM
stom's Avatar
stom
Your connections are all correct Giggzz. The 3(B) wire from the 99 harness goes to the 11(A) pin on your 430 harness. That's the wire that powers the lights on the radio buttons. Hope this helps.
Old Jul 24, 2007 | 06:50 PM
Giggzz's Avatar
Giggzz
Here is what I have come up with on the pin connection:
11(B) connects to 12(A) disregard 1(A)
1(B) connects to 4(C) disregard 4(A)
7(B) connects to 4(A) disregard 8(B)
5(B) connects to 10(A) disregard 10(B)
15(B) connects to 9(A) disregard 9(B)
19(B) connects to 7(A) disregard 6(B)
8(B) connects to 1(A) disregard 1(B)
18(B) connects to 6(A) disregard 5(B)
20(B) connects to 7(C) disregard 2(A)
How does this look?
Thanks for the help, very much appreciated.
Old Jul 25, 2007 | 04:58 AM
stom's Avatar
stom
How does this look?
These new connections are all wrong. The 'disregards' are the right ones. And the 11B connects to both 1A and 3B.
Old Jul 25, 2007 | 08:42 AM
DrexLex's Avatar
DrexLex
I think you meant to say 11(B) in both cases. That’s the ACC lead.
I think you misunderstood what Giggzz was describing. He was showing the connections of the 2003 radio to the 99 amp. He did so correctly. However, your point is correct that this is not what he needs to tie together in order to make his plug-in adapter for the 2003 radio.
Assuming he is leaving the car’s original radio harness connectors in place, and has found direct mates for them, then the wiring task is all about making an adapter that translates the 99 radio to the 2003 radio. To do that, connect the wires in the “1999 radio” column to the wires in the “2003 radio” column.
What is freaky, is that the TW pinouts for the 2003 radio exactly matches the 99 radio pinouts. It means the 2003 radio would directly plug in to the TW version of the 99 GS. Somehow the TW version was using the new pinouts ahead of the EX-TW version.
