Help Needed由X 450h OEM LED Swap with HID
Old Jun 16, 2026 | 09:51 PM
Scruffers92's Avatar
Scruffers92
2nd gear
Default Help Needed由X 450h OEM LED Swap with HID
Hello folks,
I知 rebuilding a 2012 RX 450h after a little accident. The car comes with stock triple beam LED headlights with AFS. One needs to be replaced. Cheapest on EBay is $900. That痴 out of my budget.
Question:
If I get OEM HID痴 and the wiring harnesses, can I monkey around with the wiring and make it work? Is this a bad idea?
Folks convert 2010-12 HID to 2013+ HID harnesses.. The LED to HID wiring is an unknown.
Old Jun 17, 2026 | 12:36 AM
6runner's Avatar
6runner
Have a look at TLS Auto Parts or Yota Auto Parts for the correct used headlight;
https://www.tlsautorecycling.com/
https://yotaautoparts.com/
Old Jun 17, 2026 | 05:43 AM
Clutchless's Avatar
Clutchless
Here is another source of used parts that searches yards all over the country. Hollander has the database that all vehicle recyclers use to determine which parts fit which vehicles. https://www.hollanderparts.com/
I would stay with Triple LED as it may be a nightmare trying to get the wiring to work if you change the headlights to HID.
You may not like paying for the Triple LED, but it will avoid hours or weeks of issues trying to get HID to work in that vehicle, if they can be made to work.
Old Jun 17, 2026 | 08:34 AM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by Scruffers92
Hello folks,
Question:
Anything other than replacing with identical is a bad idea. Even if you have light source marking the corner, there will be an error message on your display.
Next thing to be aware is that even when you get the replacement assembly, the mount points need to be brought back to factory spec w.r.t. body. <- Please make sure those are not shifted on account of an accident.
I would urge you to go through the insurance claim and use good repair shop. DIY will cost you more than your detectable.
I know it might impact your premium, but at least do the math.
Salim
Old Jun 17, 2026 | 08:55 AM
Alex1989's Avatar
Alex1989
Rewiring isn't a major issue if you know what you're doing. However, the thing is, if you have a pre-facelift model and want to install facelift headlights, you will also have to replace the front bumper.
p.s. I recently installed "new-style" projector headlights庸eaturing LED "angel eyes" or halos熔n my boss's Mercedes G-Wagen, even though it originally came with halogen headlights. There are no error lights on the dashboard (I simply ordered the necessary "error cancellers" and so on).
Old Jun 17, 2026 | 11:18 PM
Scruffers92
2nd gear
Thank you for the help. The salvage yards are asking $800 and up for the LED light.
i have a HID light and sourced a harness. I plan to splice the wires without cutting them to see if it will work. I bought the car as a write-off from an insurance auction. It has a salvage title. I might go for the OEM LED route if it had a clean title.
piercejr
Nov 18, 2020 03:16 PM
maryhadit
RX - 1st Gen (1999-2003)
Oct 3, 2018 08:52 AM
davesb6875
Feb 5, 2018 02:40 PM
kingnicky
May 26, 2015 07:50 PM
GQis350
Jul 29, 2012 01:07 AM
