TX Models (2024-present)
Mudguards and Running board
Old May 21, 2026 | 07:59 PM
yoursuf's Avatar
yoursuf
1st Gear
Default Mudguards and Running board
Hello, just purchased 2026 TX350 and looking to purchase Grand highlander running board and Mudguard from Toyota as they currently have sale going on. Can anyone confirm if they fit TX350 who has already done that? Thanks a lot in advance.
Old May 22, 2026 | 02:26 AM
gvan1998's Avatar
gvan1998
Why dont you buy it and let us know.
Old May 22, 2026 | 10:04 AM
DonsCA's Avatar
DonsCA
If you have the part numbers, there is probably a reference if they are cross compatible,
Old May 24, 2026 | 07:53 AM
trdrolla's Avatar
trdrolla
7th Gear
Yup, they fit. I got the highlander running board from a Toyota dealership as they were having online sale new customer for 10% off + mothers day 15% off. They're the exact same part # as for the Lexus TX. However the mudguards/cargo trunk lamps are different part numbers.
Running Board Part # - PT938-48240 for TX/Grand Highlander
Mud Guards Part # - PK389-48R00-TP- Grand Highlander
- PK389-48R50-P1/TP - TX
Old Today | 06:23 AM
MiFu's Avatar
MiFu
Does the running board block the pinch welds and jack points along the side of the car where it is safe to place a jack to lift the car?
I usually change my tires at home (summer / winter tires) but from pictures I have seen, it's hard to tell if the dedicated area to safely lift the car is blocked by the running boards.
I would like to get running boards in the near future, but if it's something that will be an inconvenience while using a pump jack to change the tires, then I'll have to reconsider getting them.
Does any one have pictures of the running boards installed and under the car to see the pinch weld/jack points?
Old Today | 07:16 AM
trdrolla's Avatar
trdrolla
7th Gear
Just took some quick pics for you. You'l need some sort of jack pad extender or a block of wood to clear the running boards. There are front and rear jack points on the subframe, so you can lift the front/rear and place it on jack stands no problem. But if you want to jack from the side, you definitely need extenders to clear the running board.
mbarron37
Jun 27, 2024 05:32 PM
rad-man
Feb 18, 2016 09:20 PM
Kermee
May 16, 2006 09:46 AM
