V6 Idle Vibration - Solutions?
Old May 14, 2026 | 09:41 AM
TrickCoffee9183's Avatar
TrickCoffee9183
1st Gear
Default V6 Idle Vibration - Solutions?
Has anyone finally been able to resolve or atleast eliminate majority of the idle vibration on the 4th gen RX350?
I feel noticeable but not violent vibration under my seat at idle in D or R, not in P or N. I have been looking into possible solutions for months and I’m just hesitant to pull the trigger on replacing engine mounts on the car as a last resort.
My 2017 RX350 (104k kms) idles at like 580-610 rpms from what I can gage from BlueDriver. Its particularly annoying to deal with in stop and go traffic.
I’ve tried MAF sensor cleaning, throttle body cleaning, injectors, changing fuel type (87 to 91/93), putting in fuel injector cleaner (BG44k) and nothing has eliminated the vibrations yet so far.
Car otherwise is really enjoyable to drive. Hopefully someone has a solution they can recommend!
Old May 15, 2026 | 10:38 AM
703's Avatar
703
Yes. Swap for the hybrid instead.
Old May 15, 2026 | 03:57 PM
LarLex's Avatar
LarLex
Why not just increase the idle rpm via an OBD-2 programmer?. In the carburated days, it was just a screw you turned. A bit more complicated now. Have you taken it to a mechanic?
Old May 16, 2026 | 01:30 PM
GS4_Fiend's Avatar
GS4_Fiend
You cannot do that because it's all programmed to be controlled by the PCM.
Old May 18, 2026 | 07:14 AM
Clutchless's Avatar
Clutchless
How long have you owned this vehicle?
If new to you, it may be normal, and you need to get used to the new noises of this vehicle. It is not uncommon, and we have had similar requests previously.
You have low mileage for issues to show up or have a motor mount failure and you have already addressed any fuel system issues.
Have you checked for stored codes or had a shop check it out?
Or done a transmission fluid change. This is the time to get that done, and it may help.
erichuang
Sep 17, 2024 10:07 AM
Jtrnz03
Maintenance
Jun 30, 2023 02:36 AM
biosurfer1
Oct 25, 2021 09:42 PM
brybo86
Nov 18, 2015 09:13 PM
ilovefood
Aug 31, 2009 06:38 AM
