2014 FSport Suspention
Old Yesterday | 05:58 PM
igabranifsport's Avatar
igabranifsport
3rd Gear
Default 2014 FSport Suspention
I’m looking for replacement suspension components for my 2014 RX350 F Sport (Canadian model), specifically front struts and rear shocks. I’ve had trouble finding the right parts.
I came across some strut kits on RockAuto, but they appear to be for the standard RX350. I’ve also read that the F Sport version may use different springs compared to the regular model—can anyone confirm if that’s the case?
If anyone has sourced compatible kits or parts, I’d really appreciate it if you could share links or recommendations.
Old Yesterday | 06:35 PM
6runner's Avatar
6runner
Originally Posted by igabranifsport
I’m looking for replacement suspension components for my 2014 RX350 F Sport (Canadian model), specifically front struts and rear shocks. I’ve had trouble finding the right parts. I came across some strut kits on RockAuto, but they appear to be for the standard RX350. I’ve also read that the F Sport version may use different springs compared to the regular model—can anyone confirm if that’s the case? If anyone has sourced compatible kits or parts, I’d really appreciate it if you could share links or recommendations.
How many miles is on your F-Sport ? On recommendation from this forum recently installed Bilstein B6 24282901 shocks from RockAuto on our car along with new sway bar links and bushings and found those took out enough body sway that I'll leave the front struts alone for now, B6's are stiffer than base stock and close to F-Sport feel. When doing the fronts when needed will likely use Sachs struts from RA recommended for F-Sport and reuse original springs for a stiffer aftermarket setup on this Sport Design model.
https://www.rockauto.com/en/parts/bi...k+/+strut,7556
Old Today | 12:09 AM
MattRX's Avatar
MattRX
This gen of F-Sport uses the same springs as a regular RX, just the shocks themselves have stiffer valving. Bilstein B6 if you want a firmer ride like the F-Sport units, Bilstein B4 / KYB / Sachs if you want non-F comfort ride. The TRW/Sachs F-Sport firmer struts do not seem to be available anymore from Rockauto at least
Also, don't get quick struts, get actual strut cartridges and move over the OEM springs no matter what. There are lots of postings on the forums of people regretting installing quick struts and having to go back to OEM and paying big time for the stock springs. All quick struts are complete garbage and will make your car ride and handle awfully
CrazyChino
NX - 1st Gen (2015-2021)
May 5, 2017 06:08 PM
DVS
Dec 25, 2016 07:10 PM
DatsunME
Suspension and Brakes
93
Dec 10, 2015 03:21 PM
cdo221
Jul 21, 2014 06:50 PM
Clutchless
RX - 3rd Gen (2010-2015)
Apr 26, 2012 06:26 AM
