Alternator charging issue
Old Apr 17, 2026 | 06:33 PM
Tvez's Avatar
Tvez
8th Gear
Default Alternator charging issue
Hey all,
I recently did a battery relocation on my 99 GS300. Moved the battery from the front, to the trunk. I used 1/0 AWG wire from the battery, to a 250amp fuse, then to a junction block in the engine bay, where I have the stater, and fuse box connected to (fuse box is charged by the alternator on this car or so it looks) than I have 1/0AWG wire from the negative straight to the chassis in the trunk and than 1/0 from the chassis in the engine bay to the engine block. My grounds seem fine, and the car starts and will charge fine at idle, but when I turn my accessories on, radio, lights, heat, the voltage starts to drop very fast. When checking with a multi meter and no accessories on, battery seems to stay charged at about 14.07 volts. When accessories are on, it drops about .5 volts every 2 minutes or so, it got down to 12.13 volts and kept going until I turned off the accessories then it only charged itself up to about 13.6. Is this normal or does this seem like an alternator issue?
I cant drive the car around yet, I have a tuning session scheduled for may, so only been able to see this at idle. Perhaps this alternator which is the original is just no good or can’t keep up with the load at idle rpm?
I noticed this when I removed it too, this metal piece was broken on the back and I don’t know how important it is. Removed it because I ordered a new one to see if that helps my issue. But I’m still asking on the forum to see if I’m chasing the wrong thing. I have added gauges, a higher flow fuel pump and larger injectors, the stereo is after market but I don’t have a sound system with it. I wouldn’t think these would put that much more stress on the alternator . Any hep would be appreciated.
Is this some sort of grounding piece?
Old Yesterday | 05:11 AM
TrueGS300's Avatar
TrueGS300
I think some auto parts stores still have alternator tasters. You could have the old one checked and see if a new one is the fix.
Old Yesterday | 06:12 AM
dwoods801's Avatar
dwoods801
Ya, u need to find how much power your old alternator was putting out. When u move the battery to te trunk and asked the longer cables, there will be some voltage drop, make the serpentine belt is fresh, and isn’t slipping or anything
Old Yesterday | 06:27 AM
Tvez's Avatar
Tvez
8th Gear
well that’s why I updated the wire from I believe original size was 4awg to the larger 1/0 AWG. Power house racing sells a relocation kit for the IS300 that uses this size, so that’s why I figured it would also be okay for the GS. Serp. Belt is brand new it came with my A/C delete bracket, and is pretty tight. Also, now the A/C fan and radiator fan both reference the coolant temp to activate, instead of A/C fan referencing A/C pressure. It works as it should, and only turns on once coolant reaches 190 then turns off when it gets back down to 170-175.
davet1
May 22, 2022 11:53 AM
Jdub82
Oct 31, 2021 12:48 AM
2Gen430
Jan 13, 2019 11:59 AM
hotshot27
Jun 15, 2013 06:37 PM
nicks88
Jun 12, 2012 06:57 PM
