Alternator?
Old Oct 30, 2021 | 04:02 AM
Jdub82's Avatar
Jdub82
Default Alternator?
Car was having to be jumped often with 11.4v on battery. Battery was a few years old so I went ahead and replaced the battery first. Idle is a little low and even in park with a little acceleration the radio will cut out and p/s will turn off and VSC Trac light comes on until you let off the gas. Am I right in thinking it's just the alternator not supplying enough volts and turning electronics off?
Old Oct 30, 2021 | 06:21 AM
ibidu1's Avatar
ibidu1
Put a voltmeter to the terminals and test what the cars voltage is at idle
Old Oct 30, 2021 | 02:59 PM
Jdub82's Avatar
Jdub82
When I initially jumped it it was at 13.6-8 volts than idle started dropping and after about 5 minutes it was around 12.6 volts. Pulled the alternator fuse while running to see if there would be a significant drop and I'd just stayed the same 12.6-8v. Tried pulling fuses on other systems like dome,radio etc and nothing changed. I'm leaning toward the alternator, just not being a big electrical guy I wanted to make sure I went about it the right way.
Old Oct 31, 2021 | 12:48 AM
ibidu1's Avatar
ibidu1
You need a new alternator, throw in a denso brand or a remanufactured denso
TRENTIMUS
GS - 1st Gen (1993-1997)
Jan 31, 2019 03:41 PM
AntzCro
Jan 18, 2019 07:55 AM
DMPesso
Nov 19, 2014 08:47 AM
alexamparo
Oct 5, 2002 02:18 PM
