CarPlay upgrade for 2019 model
Old Apr 2, 2026 | 02:06 PM
buma614's Avatar
buma614
1st Gear
Default CarPlay upgrade for 2019 model
I didn’t know when I purchased my car a couple months ago that it did not have native CarPlay and required my phone to be plugged in with a cable. I also missed having a touchscreen. Did some research and decided on replacing my unit with a Linux based replacement from Lexion. It was surprisingly easy to self install. Any issues I had, their customer service was available by WhatsApp and answered super quick and solved my issues quickly as well. Screen is very clear and system is quick! Definitely recommend this to anyone interested in the same type of upgrade.
Old Apr 3, 2026 | 03:17 PM
faisal11ir's Avatar
faisal11ir
Just upgraded to Lexion a week ago even the track pad works like factory. highly recommended.
Old Apr 4, 2026 | 12:28 PM
05RollaXRS's Avatar
05RollaXRS
Good info. Putting it down in my list of things to do. My 2016 infotainment is extremely dated even compared to my 2017 RX350 F-Sport and the 2019 IS350 F-Sport that I have. Might consider this in the next year or so.
Old Apr 6, 2026 | 02:54 PM
br116's Avatar
br116
Good to know, but I went with Hamilton will update after install and test.
Old Apr 7, 2026 | 01:40 PM
faisal11ir's Avatar
faisal11ir
Lexion is super it's fast wireless and the track pad works like factory even with vibration, also the AHD cameras especially the front is very helpful. The system is very well optimized.
Old May 18, 2026 | 12:58 AM
Sunseeker0911's Avatar
Sunseeker0911
1st Gear
Hello, do you have rattles or squeak after the conversion?
Do all the button works including the steering wheels?
how long did it take you? Would love to see a picture.
Thanks!
Old May 18, 2026 | 03:00 AM
JT2MA71's Avatar
JT2MA71
If you have the smaller screen and you're going with the larger Lexion or any aftermarket Android/Carplay display, I think it's a good idea to replace the instrument cluster hood with one from the facelift models so the lower left corner of the screen is unobstructed. You can see the difference in the first picture (start button area)
Old May 18, 2026 | 07:42 PM
lojackfty's Avatar
lojackfty
there is a firmware, I did it on my 2019 and have carplay now even though initially it didn't come with it.
Old May 19, 2026 | 07:53 PM
faisal11ir's Avatar
faisal11ir
Firmware from Lexus? can you share details please
Old May 21, 2026 | 07:56 PM
lojackfty's Avatar
lojackfty
This will work for 2018 and 2019 Production years for the RCF
Here is the website link. Read the LSB First and make sure your model ID matches the file you are using. Follow directions to the T, once the update the update starts, be patient and watch, don't intervene and just WAIT. You will know when its done, I would suggest printing the LSB so you can follow along step by step. There will be times you think it might be frozen and not doing anything, but it's NOT FROZEN be patient and FOLLOW DIRECTIONS. If you interrupt the process because you think its FROZEN or you are impatient you could BRICK your Head Unit. Now that I've scared the HELL out of you best of luck, be patient, follow directions and do exactly what it tells you to do. Once its done, you will have carplay only, it will not give you ANDROID AUTO.
Here is the link, go to the bottom of page where the purple banner starts, thats the RCF SECTION. Download the file and set up your thumb drive the way it tells you too.
UpdateIT
2019 Lexus NX300, NX300H, RC F, ES300H, ES350 Carplay Update | TSB and Update Files
READ LSB FIRST – Match Model ID with correct update files and use the links below to download update files.
2019 Lexus LSB
L-SB-0027-19 – Pioneer (without navigation)
L-SB-0028-19 – Panasonic (with navigation)
Update Files for 2019 NX300, NX300H, RC F, ES300H, ES350 (Copy every file within the update zip folder onto the USB. Do not leave any files behind or do not pick and choose specific items; take everything)
2019 ES300H, ES350 – Firmware UPDATE – Pioneer (READ LSB FIRST)
2019 NX300, NX300H, RC F – Firmware UPDATE – Panasonic (READ LSB FIRST)
*** Lexus Only. The eManual might disappear after the update. If it does, make a post in the thread and I’ll PM it to you. ***
Old May 24, 2026 | 07:46 AM
CinFulxgs's Avatar
CinFulxgs
For the Lexion, can anyone explain the front and rear camera purchase options? Doesn't it already work with the factory rear camera?
seedybest
Jun 28, 2025 10:17 AM
GS350MIKE
Jun 17, 2024 07:58 PM
Kaianuanu
Aug 24, 2022 09:04 AM
halovoa
LX - 3rd Gen (2008-2021)
Jun 21, 2020 11:18 AM
cory143
Feb 15, 2018 10:55 AM
