Air suspention only starts working only after pressing up/down
Old Mar 30, 2026 | 07:09 PM
kutsyy's Avatar
kutsyy
Default Air suspention only starts working only after pressing up/down
I am wondering if anyone has seen this before. When the car starts, the air suspension doesn't start at all, no matter how long I drive, [so the rear will slow lower]. However, if I click the up or down suspension button, the air suspension starts to work perfectly. It doesn't matter if the car sits overnight, or if I just turn it off and on.
Thanks,
Old Yesterday | 11:16 AM
ALAN553's Avatar
ALAN553
Any rear suspension issues….the first place to look is for pinholes leaks in the airbags. There are many many posts here that should leave you to a diagnosis
Old Yesterday | 11:23 AM
kutsyy's Avatar
kutsyy
I have new airbags.
Old Yesterday | 01:59 PM
chiph9's Avatar
chiph9
Then the next thing to look at is the height sensors. Since you're in California, rust shouldn't be a concern .. but check them anyway.
Chip H.
Old Yesterday | 03:12 PM
kutsyy's Avatar
kutsyy
Chip H.
sensors and the rest of the suspension works great. All the information provided via Techstream is correct all test are fine.
However, systems starts working only after you press up or down button. Prior to it, compressor doesn’t quick off (and yes both sensors shows up to -70mm hight from normal).
Old Yesterday | 07:54 PM
tz693's Avatar
tz693
Thanks,
I have same issue. The car slowly dropped during the cold days. Start and drive the car doen't bring it up. Only press the up/down button brings it to level.
Old Yesterday | 08:15 PM
kutsyy's Avatar
kutsyy
Just wondering, did you ever modify the ride height in the Techstream ? [i.e., in software, not by adjusting the sensors mechanically]
DaOne
IS 500 (2022-2025)
Oct 17, 2023 09:27 AM
ReeM
Suspension and Brakes
Nov 22, 2016 07:10 PM
gcam77
GX - 1st Gen (2003-2009)
Feb 16, 2016 07:39 AM
trevor80
Dec 24, 2010 07:59 AM
