Number of turn signal flashes
Old Mar 27, 2026 | 08:50 AM
lsbrodsky's Avatar
lsbrodsky
Veteran: Navy
Default Number of turn signal flashes
I keep forgetting to ask the dealer to do this and since I don't plan to be back there anytime soon, I did a search. Nothing on the IS500 forum, but I found this on the broader IS forum: https://www.clublexus.com/forums/is-...s-to-more.html
It works just fine and is also reported on Reddit and the other Lexus forum. Convoluted and makes you wonder why, with all of the Settings available for the owner, this is not a normal owner setting. My Carista wouldn't do it either. In any event, I now have 5 flashes when I change lanes.
Old Mar 27, 2026 | 08:53 AM
wthrman2's Avatar
wthrman2
^^ LOL - My wife would be happy if I used the 3 flash, I never use my blinkers or rarely do but that manual step by step description in the link your provide is quite something! Thanks for sharing though
Old Mar 27, 2026 | 09:08 AM
lsbrodsky's Avatar
lsbrodsky
Veteran: Navy
Based on my review of this club, the other Lexus forum, and Reddit, there are a lot of opportunities to make a mistake in following the instructions. But most people report success, eventually. I screwed it up once but then got it right and now have 5 flashes. My mistake was the final step; I pushed the turn signal all the way down instead of just to the flash. Had to start all over.
Old Mar 27, 2026 | 08:22 PM
Benibiker1558's Avatar
Benibiker1558
O M G! So complicated!! I'll try it one day .
Old Mar 28, 2026 | 05:39 AM
EngIceDave's Avatar
EngIceDave
OK, hold on….it only blinks three times? So if I leave it on like the dork I am, it really only flashed three times?
If so, whew!
Old Mar 28, 2026 | 06:19 AM
lsbrodsky's Avatar
lsbrodsky
Veteran: Navy
Yep, the default is 3 flashes! If you just flick the stalk to the "lane change" position, it will flash 3 times. The book and the hack say the capability is there for 3, 5 or 7 flashes but the book tells you the dealer has to do his voodoo to make the change. Clearly, not so.
Old Mar 28, 2026 | 10:28 AM
Torethyr's Avatar
Torethyr
I know it a convoluted process but I'd rather it be convoluted than require an obd2 programmer/techstream.
Too many options require techstream. I want to change the volume of the blinker clicks but I just refuse to pay the carista sub
Old Mar 28, 2026 | 06:25 PM
Benibiker1558
If so, whew!
No, it's the lane change feature where you just push it down halfway, not all the way and let it go, it'll just flash three times by default. If you push it down all the way, it'll keep blinking till someone honks or throws you the middle finger. LOL
Old Mar 29, 2026 | 04:15 AM
EngIceDave's Avatar
EngIceDave
There’s a halfway?
Old Mar 29, 2026 | 04:59 AM
lsbrodsky's Avatar
lsbrodsky
Veteran: Navy
If you push the stalk all the way up or down it goes into a detent until you make a turn then it goes off. However, if you push it up or down a bit from horizontal and release it then it returns to horizontal and flashes 3 times by default. But, there is a hidden capability to flash 5 or 7 times instead. All of my vehicles have had this for a long, long time.
Old Mar 30, 2026 | 10:46 AM
arentz07's Avatar
arentz07
I did the 5-flash setting myself in the garage. I followed the instructions here - https://www.clublexus.com/forums/is-...ml#post8496856
I edited part of it to be clearer about the part that tripped up others and me.
Old Mar 30, 2026 | 10:58 AM
wthrman2's Avatar
wthrman2
Do you guys all drive around your IS 500 in trenchcoats flashing people multiple times?! (LOL)
Old Mar 30, 2026 | 02:09 PM
EngIceDave's Avatar
EngIceDave
There’s a halfway?
Well I’ll be darned, there is a halfway where it only blinks three times.
Old Mar 30, 2026 | 03:40 PM
Benibiker1558
^^^ These cars are full of surprises!
Old Mar 30, 2026 | 05:21 PM
Bechtold's Avatar
Bechtold
I flash people seven times when I use my turn signal! That is with no trenchcoat required.
