Knock sensor harness didn’t match up
Old Mar 25, 2026 | 09:05 AM
miguelo007's Avatar
miguelo007
1st Gear
Default Knock sensor harness didn’t match up
Recently I’ve gotten a bank one knock sensor code and I got the new knock sensors and new harness which has 2 connections, one for each knock sensor and a connection that plugs into the firewall. The harness that is on there though has 3 wires the 2 knock sensor connectors that are a brown and black wire and a black red striped wire that has a green connector that plugs into something on the starter. Does tgis sound like a jimmy rig or like a previous owner did something weird? I’ve had it for a year without knock sensor codes so it must’ve been working but I can’t find a harness that matches the one that was on there currently.
Old Mar 27, 2026 | 04:17 AM
TrueGS300's Avatar
TrueGS300
I'm not seeing any harnesses w/ the third wire either. I guess you'll have to open the loom and separate the wires. Could be someone's past repair from rodent damage.
Old Today | 06:24 AM
dwoods801's Avatar
dwoods801
That’s factory plug, they only used em for a couple years and now they are discontinued so u can’t get a replacement. So replace the knock sensor plugs.
Mylex400
Sep 25, 2025 08:51 PM
luey2010
Oct 17, 2010 08:42 PM
mrchacon
Jun 29, 2009 12:34 PM
