New TSB L-SB-0048-25 for transmission downshift clunk
Old Oct 24, 2025 | 09:18 AM
dhspeed's Avatar
dhspeed
10th Gear
Default New TSB L-SB-0048-25 for transmission downshift clunk
Just saw someone posted this over at reddit. If someone had it done already, any issues afterwards?
The description sounds like what I'm experiencing when slowing/coasting to a stop for 5-4 or 5-3 downshifts although its less noticable after 10-15 minutes of warmup.
Old Oct 24, 2025 | 09:28 AM
FirstLexusIS500's Avatar
FirstLexusIS500
^^^ I googled that TSB and it appears to be for the GX 550 and a hood flutter issue. Correct me, if I'm wrong.
Old Oct 24, 2025 | 09:43 AM
dhspeed's Avatar
dhspeed
10th Gear
Just released yesterday apparently so probably why nothing shows up on google. Post with screenshot of the TSB: https://www.reddit.com/r/Lexus/comme...wnshift_clunk/
Old Oct 24, 2025 | 10:37 AM
arentz07's Avatar
arentz07
Amazing news. I always had a bad feeling about that noise.
Old Oct 24, 2025 | 12:29 PM
kenji211's Avatar
kenji211
I was wondering when this TSB would come out and I it is reassuring to know others are hearing/feeling this same issue.
For those that have reflashed ECUs, do you think this will erase your existing tune?
Old Oct 24, 2025 | 01:46 PM
V8Brah's Avatar
V8Brah
This is just an excuse for service techs to drive the car.
On a related note, if they can do this, why not reprogram the transmission altogether to make it more zippy?
Old Oct 24, 2025 | 03:22 PM
arentz07's Avatar
arentz07
Dumb answer? Cause they hate fun.
Serious answer? Wear management strategy.
Old Oct 24, 2025 | 03:28 PM
InfraGhost_500's Avatar
InfraGhost_500
So it looks like if you don't have this happening, there is no reason to take it in for service, correct?
Old Oct 24, 2025 | 03:30 PM
arentz07's Avatar
arentz07
You don't have it? Lucky.
I guess not. I wouldn't bother unless it's an issue for you. If nothing else, it seems like this issue doesn't grenade the transmission after a few thousand miles (if mine is anything to go by). Mine has done it since day 1, over 2.5 years and 23,000 miles ago.
Old Oct 24, 2025 | 03:39 PM
V8Brah's Avatar
V8Brah
I would argue a well-tuned transmission would cause less wear because when you mash the pedal everything is just smoother - I could be wrong though.
Toyota/Lexus is such a mess. Their inconsistency when it comes to listening to customers is absolutely infuriating. Follow my logic:
(+) they come out with the IS500 (V8)
(-) they keep a 10 year old interior and transmission
(+) they extend the life of the IS in 2026
(-) they make the exterior worse
(+) they update the interior
(-) they drop the V8 from the next IS
(+) they release a TSB for the IS500 transmission
That's just the IS lineup in a nutshell. Don't even get me started on their boneheaded decisions regarding the ES, RC, LS, and GS.
Old Oct 24, 2025 | 04:38 PM
arentz07's Avatar
arentz07
Keep in mind the TSB says something specifically about the "fuel cut logic", so I don't know whether that would have anything to do with the overall performance of the transmission.
edit: OK I reread it, and it also mentions the transmission control unit. Hmm.
Old Oct 24, 2025 | 04:51 PM
wthrman2's Avatar
wthrman2
I am not sure I understand what you guys are experiencing/describing - It is likely a sign that I don't have it or that I just assume it is part of how this thing is
Old Oct 24, 2025 | 06:26 PM
zcheng3's Avatar
zcheng3
There is a simple fix for this - drive it in sports plus mode and drive it like a V8. I am averaging 16mpg and I rarely run into this.
Old Oct 24, 2025 | 10:18 PM
Benibiker1558's Avatar
Benibiker1558
I remember they came out with something like this for one of my Minis and after the update the car felt lazy as hell! It was a completely different car afterwards and just plain sucked. I'd be careful with this TSB .
Old Oct 24, 2025 | 10:46 PM
V8Brah's Avatar
V8Brah
This crossed my mind too since they botched the front apron separation TSB. I think I'll wait for the reports from others before going myself.
Sad you can't trust Lexus anymore.
