Upgrading base model to better package
Hey CL veterans, I was wondering if there is a list of all possible package upgrades that are possible to do on a base model to make it look like a better package? Or perhaps what I'm asking is how easy each upgrade is? Now, you may say "just buy one with a better package man", haha easy for you to say, if you don't live in a country where it's easier to find mint condition manual Ferrari than a manual IS250 (and importing is too expensive, for the price of this car, due to stupid emissions tax). However, what's not rare are crashed IS220Ds. So I was wondering, which parts can you just steel from one, and install relatively straightforwardly. This is the list of options that I can think of, and my guess on the level of effort:
1. wood grain - very easy
2. navigation unit - time consuming, but doable if you can follow wiring diagrams and stuff: https://www.clublexus.com/forums/is-...-the-swap.html
3. xenons (and washers, levelling mechanism, etc) - not hard if you are fine with some of the features missing, full conversion - forget about it
4. sport pedals - relatively easy
5. memory / leather seats - ??
6. ventilated / heated seats - ??
7. door leather - medium?
8. auto dimming side mirrors - ??
9. auto dimming cabin mirror - medium, you'll have to do some wiring, but it's not complicated
10. parking assist - medium? https://www.clublexus.com/forums/is-...ng-assist.html
11. rain sensor, auto wipers - ??
12. rear shade - forget about it?
13. powered (non-manual) telescopic steering wheel - hard?
Feel fee to guess even if you are not sure, thanks!
EDIT: I've updated the post with info from answers.
1. wood grain - easy
2. navigation unit - hard?
3. xenons (and whippers, levelling mechanism, etc) - forget about it
4. sport pedals - medium?
7. door trims - medium?
9. auto dimming cabin mirror - ??
11. rain sensor, auto whippers - ??
13. automatic steering wheel - hard?
jedan (05-27-24)
1. Simply a swap
2. Nav swap: https://www.clublexus.com/forums/is-...-the-swap.html
3. It is a direct swap, but the bi-xenon and the AFS will not work without rewiring if you have factory halogens. If you dont care about AFS, you can skip that step with the 11+ led strip headlights. You'll have to do some searching around here for those who have done the swap.
4. Simply a swap.
5. Leather seats should be a direct swap, most here are based in the US though and leather was the base option so you may not be able to find too much info on the cloth seat swap. Memory seats are not happening though.
9. I dont believe the base 250 with the non auto dimming rear view mirror is prewired for it, so you'll have to tap into the wires in the headliner. Not hard at all.
jedan (05-28-24)
For the memory seats I believe its 100% possible and would just take time and money. What is the automatic steering wheel and door trims you mentioned? Also, have you not considered doing the parking assist retrofit? Its actually really easy, and I can help you out with it if you have any questions.
I'll be seeing about doing mods 4, 5, and 12.
By "door trims", I mean changing door interior parts to leather. Not sure how easy is to switch only the leather parts, but I've seen people basically just changing the whole inner part of the door (usually to fix rotting plastic issue). I don't think it's hard, probably just time consuming. By "automatic steering wheel" I mean powered (non manual) telescopic wheel, that auto adjusts itself into driving position when you start the car. I'll edit the post to make it clearer.
Yes, parking assist is on top of my list, that one is arguably the only "must have" one for me. But it's parts are in high demand, so you gotta be quick, I was already late couple of times . I think I'll probably end up gathering all the parts from ebay...
Oh yeah I'll definitely be seeing about getting my door panels wrapped in leather, I also got the sticky dash issue. I'm pretty sure the powered telescopic steering wheel is tied in with the memory seats, but I don't see why you couldn't just install it by itself, which I'm actually going to see about doing. All I should need for that is the powered steering column and the switch that actually moves it.
1. Simply a swap
4. Simply a swap.
4. Simply a swap.
jedan (05-28-24)
Btw, while I have your attention, do you know where I can find PGEAR FW1224005 steel SMF? It seems it has disappeared from the internet... Or can you perhaps recommend some other steel SMF? IIRC you were using it temporarily because it was cheap. Are you on some other setup now (just post links to thread if you have one, thanks)?
bladest
11-20-21 01:23 PM
