ES300h driver rear door trim not even causes wind noise around 65-75mph
10th Gear
Hello,I am moving from GX470 to ES300h. Taken delivery last two weeks. I have some concern regarding windnoise that come from driver window at interstate cruising speed right around 65-75mph. Everything else is quiet except the wind noise only at driver window. Has anybody comes across this? Is this a concern? So I check at the door and found out that the chrome window trim at driver side rear door is not even with the front but not at the passenger side. Which my wife hear nothing. I also attached some photo and measurement to show the difference between two sides. Halp!!!
Both my 2021 ES300hes (brand new as well) both had massively crooked/misaligned doors and top trims and chrome. I corrected mostly what i can but the difference in the the gloss black door trims could not be rectified. because if you do, then the doors would be misaligned. its like paying tetris where some of the blocks aren't perfectly shaped. in any event ask the dealer to fix the doors.
10th Gear
Too early? Well, if it was a wear and tear issue, perhaps, but this might be a case of the door seals not being properly aligned or seated, so that is definitely a warranty issue. While it shouldn’t happen from the factory the reality is that such things do happen, and not just to Lexus. Let the dealer take a look at it and see if they can’t make adjustments to quiet the noise down.
10th Gear
6th Gear
It's not clear to me what your pics are showing. If not too much trouble, can you give a brief summary of the pics so I can try the measurements at my end too.
Thanks
10th Gear
I also have the driver side noise issue. 2024 ES300H, I noticed the noise after about 1500 miles, have about 1800 miles YTD.
Thanks
Thanks
10th Gear
Update: My car still at the dealership since May 31 and no one has update me of anything so i called them on June 7th. The service adiser said "Your car is in the bodyshop and we are waiting for Lexus engineer to take a look and our service manager still in the meeting and will call you asap". So I told the service adviser that I found out about Lexus service bulletin on 2021-2022 L-SB-0031-22 Wind noise from the rear left door.
But in my case I can hear from driver side door near the back door. So i don't know if its related. And also the door gap when closed the Rear left door is not even like the rest of the doors. Since then i still have not heard from them. Any thought on this?
Glad you're running down all possiblities
In late 2022, I had noise in my '22 ES appearing to originate from the drivers door glass area (my wife couldn't hear it from the passenger side either). As I recall the noise began around 45mph and peaked at +65mph. I took the car in withe noise complaint and the Dealer notified me of the recall notice for rear glass. They replaced the stationary rear left side glass and the annoying wind noise was eliminated. I hope they get to the bottom of your noise issue soon.
Slightly off topic here. Just got my very first Lexus 2024 ES 350 F-Sport roughly 3 months ago with only 5 miles on the odometer and now 490 miles but already has Upper and Lower oil pans leaking. It is currently at Lexus dealer for approval of repair. Maybe it is my bad luck or these car were not really that well built in the first place? The uneven gaps are here and there on my car too but because I like the design of the ES 350 so much I bought it anyway thinking I can live with it, but never expected it a brand new engine leaking oil. I suspected it was leaking before I bought it at 5 miles, but who would checking underneath of a spanking new Lexus before taking possession?
After wiped off the oil it still seeping
aliga
SC400 / 300 Classifieds
101
08-18-08 07:13 AM
