Broken middle console driver side vent.
Old 05-13-24, 09:40 AM
RichardI
2nd gear
RichardI's Avatar
Default Broken middle console driver side vent.
Hello,
2002 RX300 broken middle console driver side vent. One of the vertical vents is loose and not connected to the others. Any ideas how to fix, simple hack, or find a replacement? I googled and shopped but not that many resources or I am not searching the correct name.
Any guidance or tips would be greatly appreciated.
Richard
Old 05-13-24, 10:21 AM
salimshah
salimshah's Avatar
Received 1,029 Likes on 929 Posts
Go to online parts retailers like Lexus of South Atlanta parts and drill down to your model.
For the part you are looking for would be Interior parts -> dash [my guess]
At this time your best bet would be from salvage yards like LKQ or similar.
I have no idea how to pop out the old vent and insert the new or the dash has to be pulled apart to access from behind.
Salim
Note: As the vehicle has aged the plastic parts become brittle. At times it is better to live with a problem then to try to fix and create more.
PS: I posted this link a few days ago.
https://www.lexussouthatlantaparts.c...9-0A3D5B2AC940
RichardI (05-13-24)
Old 05-13-24, 02:57 PM
RichardI
2nd gear
RichardI's Avatar
Thank you, it is not big issue, it does divert a little air the other directions but I can live with it. Sounds like it's more trouble than its worth.
Old 05-13-24, 09:41 PM
salimshah
salimshah's Avatar
Don't let me discourage you. Please look into it and search the net and once you have the procedure weigh out the pros and cons. I have not made that repair, so I am not in a position to tell about the scope of the work.
Salim
Old 05-14-24, 05:13 AM
maxSteel
maxSteel's Avatar
I've never removed this one. I just fixed one on a VW Jetta MK4 where someone stuck one of those iPhone holders in the vent and broke a vane. Each vane has pins at the ends that fit into holes in a common carrier rail so they move as one. To replace the broken pin I drilled a tiny hole at the end of the vane and pushed the pointy metal pin from a pushpin through the carrier hole into the drilled hole in the vane.
Old 05-16-24, 11:39 AM
sktn77a
sktn77a's Avatar
I had a center vent with the same issue - the only part available was the entire surround and both vents - very expensive. That part is no longer available and I suspect the same of the side vents. You can try removing and disassembling the vent and epoxying the broken part(s). Or you may be able to find one at a salvage yard.
2TurboZ
06-03-19 07:47 AM
Hoovey689
05-10-12 03:29 PM
Quick Reply: Broken middle console driver side vent.
