Low toned "whoah whoah" sound
When I turn left, the to car makes a low "whoah" "whoah" sound that sounds like its coming from the driver side wheel area. The dealer said that the CV Boot on that side was loose and leaking, so I had it changed. However, the sound is still there when I make a left turn. What do you think is causing this? Maybe some bearings? If so, can I just put at some lube in them? How would I do that and to which ones should I do that to?
The following 2 users liked this post by GrandSedanFan:
thisguy_06 (04-24-24),
tompass (05-01-24)
It turns out that the sound was due to a plastic shield rubbing up against the rotor per the Lexus technician. Once he assisted the shield, the sound disappeared.
tompass (05-01-24)
