Hybrid Issues?
3rd Gear
Hybrid Issues?
Would appreciate thoughts on the RX350h. Are there any inherent problems or maintenance issues that are cause for concern? Any other drawbacks?
Thank you
Thank you
Please add year and milage to get more apt responses, that is if you have narrowed down to a particular vehicle.
Also read up on the differences between the hybrid and non-hybrid. Since you are not buying new, the rebates would not apply [they can be a good reason to purchase the hybrid]. Also read up on Lexus Hybrid design approach. If you were to ask me to only make one statement
Hybrids shine in stop and go.
If that does not apply, I would suggest buy the non-hybrid.
Salim
3rd Gear
It was a typo on my end, I was referring to the 450h. I currently have the RX350 and considering moving into a new 450h. Just concerned about issues with a hybrid. Any additional feedback is appreciated.
Thank you
Thank you
You have a what year RX350? and what year RX450h do you want to buy?
If you are considering a new 2023 /2024 RX hybrid I recomend you go to the forum for that generation vehicle.
Hybrid is gasoline and electric and 350 is just gasoline. Be aware that if the hybrid dies/not-working and even if the ice is working the vehicle is dead. You can not leave the hybrid garaged [not driven] for more than 3 weeks [estimate] at a stretch.
Hybrid is excellent in stop and go traffic. If you are cruising at 55 or higher the gas engine is running the vehicle.
Concerns about hybrid battery are some what over discussed but should last 10-12 years.
Ask a specific question and we can try to answer.
Salim
If you want the thread moved
Send private mail to Cluthless or any other mod to move the thread for you.
Salim
Salim
Please list items that are important to you. Currently you have left it open ended and it needs to be narrowed down.
Salim
Salim
Salim
Just some additional thoughts on how long you can leave a hybrid. It is generally recommend it you are looking for short (3 +months ) to much longer storage, a hybrid is probably not your best choice. 3 weeks for the HV is probably ok, if left in a 50% charge level.
On the HV battery, the Li-Ion have much lower self-discharge vs the NiMh HV battery, so a Li-Ion would be a less risk in general. But as noted, if you go into a low charge state, you risk even damaging the battery beyond getting the tow and the dealer to recharge it. You just don't want to go there.
On the 12v battery, a smart battery maintained is absolutely needed with the higher drain on new cars. Even 3 weeks might be dicy depending the storage conditions. However, even if you discharge the 12vbattery beyond repair or a jump charge, it is low cost compared to the HV battery to just replace.
NudleBoy
CT 200h Model (2011-2017)
11-26-19 06:43 AM
GFerg
03-20-07 12:10 PM
GFerg
02-21-06 09:26 PM
