ByPD 2006 GS300 Build Diary
Hello Gang,
I've been part of the German crowd for my entire life, I did have an affair for a couple of years with a Swede, but I always had an eye out for this particular Asian, but time passes and we grow out of it. It wasn't until a friend of mine who worked at a bank rang me up and said: "You still want a 3rd Gen Lexus GS? I have one REAL CHEAP"... 24 hrs later and a tow-truck later, it's mine...
Day One: Lex arrives at the shop!
Yes, I know here are your first tell-tale signs of the previous owner of the car: a 'GS460' badge and an uncentered shark-fin antenna... Do like the apron, anybody recognizes who makes it?
You can follow up-to-date on instagram:
bypdbuilds
bypdbuilds
Oceans13 (11-02-23)
This is Lex's engine bay.' This car was bought from a bank's repo lot, I was foretold the engine was blown and here it is. The boys will still do a full strip down to see what the culprit was. Off to find an engine...
#3 Getting it's place at the garage.
Master Mechanic Santiago Gerardo takes posession of Lex. Santiago is a specialist building engines, very meticulous and thorough. The car now will get a spot in the garage and the process of bringing this awesome car back to life begins.
Immediately you can see remnants of mods done to the car which is just downright shameful. Luckily my take will be to bring the car to a Stock + version.
Found: Healthy Toyota 3GR-FE
Found a solid Toyota 3GR-FE. Engine is clean, and taken care of. Off to the garage.
The boys at @isloversparts have a great selection of Lexus IS parts.
Front End
The front bumper and components was a hack job. No grill trim and most of the components were screwed on with bugle screws, which was a pain in the *** for disassembly. Now it's time to pull out the catalog/front diagram and sort out every screw, retainer and clip. The headlamps will be refurbished by local company that includes a ploymer to bring back the crystal-like finish.
Front End Sourcing
"You gotta do it right for it to be tight..." is something maybe my friend @shelbyscanada would agree on.
Making a list of parts needed to properly build the front end of the car.
Engine + Transmission
The 3GR is mated to the transmission. Unfortunately upon installing the fuel injectors we found a leaky one and another with a brittle connector. The wiring loom connectors are also brittle so will be replacing all of them as well.
Parts order.
We all want "overnight parts from Japan", but I'll have to settle for 72 hrs from Amazon.
These are a couple of parts and bits, fuel injector set, injector connectors, upgraded fuel pump, wheel centers, headlight trim, clips and other goodies.
Wrong wheel
So now is when I notice that one of the wheels is differente from the rest. Will have to order one of the 18" Velospinner wheels, couldn't find them locally. There is a great deal on them on Amazon. Will wait for it before sending the wheels to get refurbished. Also the fake red Brembo caliper covers must go.
The replacement Velospinner wheel is here! I love this wheel, these are a rare style in the Dominican Republic. This gives me a boost on how beautiful the other 3 wheels will turn out once refurbished. Now to get this paint color.
PS - Original Center Caps came in a previous order.
Milestone
She's in! The Toyota 3GR-FSE is in! Lex is coming together! Double checking all electrical connections, hoses, and keep finding brittleconnector plugs. Yet all seems so far, so good.
Off to get oil and parts...
