How to open the trunk when the battery is dead
Old Apr 15, 2023 | 12:37 AM
MistaLex's Avatar
MistaLex
Default How to open the trunk when the battery is dead
Hi, I'm currently on my second battery on my LC500 (Optima yellow top purchased and installed in July 2021).
I live in Montréal so I store my car from November to April. I always keep the battery plugged with a smart Noco Genius charger.
Yesterday when I tried to use the car bad surprise the battery is dead.
It's the second time that this happen to me and first time when my oem battery died I was able to jump start the car by plugging in with the positive and ground the negative.
Unfortunately this doesn't work this time cause the battery is completely dead. My smart charger doesn't even detect it and I also have a battery booster that doesn't detect it.
Now dump question but how can I manually open the trunk? I've been told that I can acces it by the middle seat behind the speaker but I wasn't able to remove that, when I tried to remove it I was a little bit scared to break something inside.
Did anyone here have a LC500 and was able to manually open the trunk?
I know most other Lexus cars have an hidden button close to the lisence plate or close to a taillight but unfortunately the LC500 doesn't have that anywhere outside the car.
Old Apr 15, 2023 | 06:42 AM
JSM701's Avatar
JSM701
Access page 369 & 370 of the manual, it gives detailed instructions how to unlock trunk when battery is discharged.
Old Apr 15, 2023 | 10:29 AM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
If the battery is completely dead a “smart” booster won’t see the battery (as you’re experiencing). You need to put the booster in override mode usually.
Old Apr 15, 2023 | 10:31 AM
Metal1's Avatar
Metal1
I junked all my OPTIMA batteries and went to ODYSSEY instead.
Old Apr 15, 2023 | 11:37 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Look Here - Post 165:
https://www.clublexus.com/forums/lc-...attery-11.html
Old May 10, 2023 | 07:13 PM
jheyden's Avatar
jheyden
9th Gear
I had the same problem on my 2022 LC500 Convertible. I hope I didn't trash my rear seat cause I yanked off the rear cover and the there was no keyhole just a black box with no hole
Old Feb 10, 2026 | 07:56 PM
jelee's Avatar
jelee
For the convertible, the emergency trunk key hole is in a different location. It is located in the lower half of the center seat back.
Old Feb 10, 2026 | 08:20 PM
Enzo954's Avatar
Enzo954
Crowbar
Old Feb 11, 2026 | 03:10 PM
ratchettt's Avatar
ratchettt
Originally Posted by Enzo954
Crowbar
I don't miss carburetors and am a fan of fuel injection. I do miss mechanical latches and dependence on batteries to just open a XYZ (well without consulting a manual and secret keys hidden within fobs, or accessing access hole)
Edit: I all my years never had a mechanical latch fail. Nor felt deprived of the electrics so required today
Old Yesterday | 08:15 PM
Ryan1100's Avatar
Ryan1100
10th Gear
Edit: no idea how I got posted on this thread, I wrote a reply to a completely different thread. Sorry!
Last edited by Ryan1100; Yesterday at 08:17 PM. Reason: No clue how I replied to the wrong thread, but here we are.
Nooblex
Jul 20, 2021 06:46 PM
woodranch
Mar 28, 2020 07:25 PM
jdanielca
Mar 17, 2020 11:44 PM
lancecov
ES - 7th Gen (2019-2025)
Apr 13, 2019 07:30 AM
caha14
Nov 30, 2013 01:58 PM
