Please Help.... Check engine light
Old Dec 9, 2016 | 07:52 AM
ROBNUTZ's Avatar
ROBNUTZ
Default Please Help.... Check engine light
I'm getting P0440, P0441 and P0446 after installing HPS cold air intake and cat back exhaust. I disconnected negative terminal when installing everything, AFTER searching the forum I read that these codes can pop up if the EGR hose isn't connected, so I triple checked my connections and still am getting a light about every 7 days after I clear the code. Any thoughts....
Old Dec 9, 2016 | 09:38 AM
kevin3344's Avatar
kevin3344
Do you have a 2GS3 or 2GS4? On my '99 GS400 these hoses were causing my P0441/P0446 codes. They were brittle and cracking. You may have to lift the engine cover to get to them.
Old Dec 9, 2016 | 12:24 PM
ROBNUTZ's Avatar
ROBNUTZ
Sorry, I should have mentioned its a 2001 GS430
Old Dec 18, 2016 | 07:39 AM
ROBNUTZ's Avatar
ROBNUTZ
You were exactly right Kevin! Thanks so much for your help!!!
Old Dec 18, 2016 | 12:44 PM
kevin3344's Avatar
kevin3344
Great! Glad you found it.
Old Jan 8, 2020 | 10:41 PM
BayAreaLex's Avatar
BayAreaLex
Got these same three codes tonight on my 2001 GS430. Will start by checking those hoses. Thanks.
Old Jan 11, 2020 | 06:34 AM
BayAreaLex's Avatar
BayAreaLex
Turned out to be a simple fix for me (vapor line disconnected) - top of engine towards driver side.
It’s the exact lines pictured above. All three codes are history (P0440, P0441 and P0446).
frotiss
May 2, 2013 09:14 PM
mbrown1782
Feb 26, 2013 07:53 PM
ap0718
Feb 9, 2009 06:04 PM
eddiej
Nov 18, 2008 08:22 PM
RNDRX
RX - 1st Gen (1999-2003)
Jun 7, 2006 04:23 PM
