DataSystems Air Suspension Controller info thread
Old Jan 20, 2016 | 11:07 AM
  #91
My1998LS40's Avatar
My1998LS40
Dr.Jerkyll: I'm happy with the set up. Did what I want and it can really lower and raise the car good. I didn't get the wireless module to link up with the main unit back then. But now, they work together nicely. I have the main sitting in the glove box and the wireless module in the center console. But, if you want the non wireless, it's ASR 680. But you'd still need the harness for your car, in this case, same as mine, the H-087i. You'll be happy with this system.
Old Jan 22, 2016 | 06:44 PM
  #92
CJITTY's Avatar
CJITTY
Note, the wired controller i have is ASC-680L, not ASR 680
Old Jan 22, 2016 | 06:48 PM
  #93
Dr. Jekyll's Avatar
Dr. Jekyll
Will that work on the 13+ too? Where did you grab yours from? Thanks!
Old Jan 22, 2016 | 07:14 PM
  #94
CJITTY's Avatar
CJITTY
Absolutely it will. I have personally set up the presets in two 2013 LS F Sports using the ASC680L controller with harness for 2013+ models. The harness is not the same as the 2007-2009 or 2010 to 2012 models. I'll have to find the harness number, but I can say with 110% certainty that regular and super low modes work on 2013+ model LS's with the wired controller.
Edit, I looked through my emails The harness for 2013+ LS with ASC680L wired controller is Type 3 (H-087i)
Old Jan 22, 2016 | 07:20 PM
  #95
Dr. Jekyll's Avatar
Dr. Jekyll
Perfect! With the F-Sport 10mm lower then a standard LS I will only need it to make minor adjustments to the settings. I did love using the ASC680 on my 04 LS430. Thanks!
Old Jan 22, 2016 | 07:32 PM
  #96
CJITTY's Avatar
CJITTY
Here is my boy's LS F Sport dropped on Data System ASC680L
Attached Thumbnails DataSystems Air Suspension Controller info thread-trin.jpg
Old Jan 22, 2016 | 07:44 PM
  #97
Dr. Jekyll's Avatar
Dr. Jekyll
Oh yeah, that's what I'm talking about! That car looks sharp but I'm looking to keep these BBS wheels so I wonder how they will look dropped. I bet it will give it just the right stance.
Old Jan 24, 2016 | 02:20 PM
  #98
Dr. Jekyll's Avatar
Dr. Jekyll
I just read on Jimmy's Black Pearl build he used a scan tool from a Lexus technician to lower his car. Is this true? Can a Lexus tech do this or someone with the scan tool? If so I wouldn't mind dropping it an inch and using the high height button to raise it up when needed.
Old Jan 24, 2016 | 07:17 PM
  #99
raefkrad's Avatar
raefkrad
I just lowered mine about an inch all around using the Toyota techstream diagnostic software. Look under setting reference height. Once done, you can then bring it back up to almost stock by hitting the height high button on your console when you feel the need.
Regards
Old Jan 24, 2016 | 07:38 PM
  #100
Dr. Jekyll's Avatar
Dr. Jekyll
Regards
Great news. How do you use that software? Is that something a shop would do or a program you can access using your computer and a plug in of some sort?
Old Jan 24, 2016 | 09:45 PM
  #101
CJITTY's Avatar
CJITTY
Interesting...very interesting indeed
Old Sep 10, 2016 | 08:49 PM
  #102
LS460LSKYE's Avatar
LS460LSKYE
Originally Posted by BLKDOUT430
I messed with it this morning and eventually it started responding...and I fixed the level by making one side slightly lower than the other...but as for the passenger side just raising to semi truck height by itself I don't know what that was all about...I'm just glad it's back to operational
I've had this issue off and on for a while but it always seems to fix itself after turning it off and back on... now my car is in semi mode and the driver side is like 3" higher than the passenger side... it literally has a 6" gap between the 22s and the fender on the driver side.. Anyone have a clue what's causing this? I'm honestly about to just get rid of the controller because I'm tired of having issues and now that it's not resetting it's really pissing me off. Luckily I have other cars to drive... I'm thinking disconnect the battery for a bit and see if that resets things.
Old Sep 11, 2016 | 09:01 PM
  #103
LS460LSKYE's Avatar
LS460LSKYE
Nobody? I disconnected the battery and reconnected and still have the same problem.... I guess I'll just have to take the controller out now...
Old Sep 12, 2016 | 07:09 AM
  #104
comotiger's Avatar
comotiger
Maybe your controller is malfunctioning. Is it Datasystems? Have you called them for advice?
Old Sep 12, 2016 | 11:37 AM
  #105
Dr. Jekyll's Avatar
Dr. Jekyll
I've used multiple DataSystem controllers and any problems have always been resolved by restarting / setting up the controller again.
