Diy beat-sonic nt3202 (ml stereo sys)
Old Nov 21, 2011 | 05:29 PM
Lexs350's Avatar
Lexs350
Default Diy beat-sonic nt3202 (ml stereo sys)
Hi gang,
I received and installed my NAV HACK bypass harnesses today. But it did come with some headaches.
I like to give a "SHOUT OUT" to Eric from Beat Sonic. I bother the poor guy for any and all questions. He not only answered every concerns I had but was also very Proffesional.
Below is some pic's to help those like me to make the install a bit easier.
The key thing to remember is to install the two new harnesses together (for those w/ML)
and be careful not to pull back on the NAV unit to far. I broke a wire and had to get it repaired. Another shout out to John from PERFORMANCE AUDIO. He was able to repair the DVD audio cable for me. I attempted to go through the dealer but they said something about changing out the entire Harness. Right.....very disappointed with my local dealer. Anyway see photo's below-hope it is helpful. Forgive me for the mispelled words....been a long day.
Don't forget to remove the negative battary cable before starting any work on vehicle
I used the following tools to perform this task.
1 Putty knife-blade covered with tape to remove silver trim on each side of the shift lever and help pry the upper vent out of the dash.
2. Jewel's screw driver to rotate upper vent tabs to the down position and to help remove the needed wire connector's back of NAV/DVD system.
3. 10mm socket with driver to remove the four bolts holding the NAV/DVD unit and to remove the negative battary cable
4. 8mm socket with driver to remove the ash tray trim assy.
5. phillips screw driver to remove plastic piece above the pedals that holds the foot well light assy.
6. flexible wire gabber to pull wires through.
7. small pillow to cover the shift lever to help not scratch the NAV/DVD unit.
Attached Thumbnails Diy beat-sonic nt3202 (ml stereo sys)-img_0129.jpg   Diy beat-sonic nt3202 (ml stereo sys)-club-lexus.jpg   Diy beat-sonic nt3202 (ml stereo sys)-club-lexus2.jpg
Old Nov 21, 2011 | 08:45 PM
Evil Teo's Avatar
Evil Teo
those little red words are hard to read. any way u can just type them out. thanks I will be doing this on wednesday. hopefully it will be ok.
Old Nov 21, 2011 | 10:58 PM
WIZARD1325's Avatar
WIZARD1325
Yea mine comes in the mail tomorrow morning NT3202. I will be installing mine on wensday as well.
Non/ML System with VAISTECH ML
This is going to be interesting
O and I have perfect eye sight and i cant read a darn thing on your pictures can you fix for us?
Thanks
The only thing I am worried about is were to run the wire for the bypass hmmm were to put it ..........ideas?
Old Nov 22, 2011 | 04:34 AM
Lexs350's Avatar
Lexs350
Sorry guys about the red text size.. will try to redo it this evening after work.
Old Nov 22, 2011 | 04:35 AM
WIZARD1325's Avatar
WIZARD1325
Also Let us know how it operates
Old Nov 22, 2011 | 11:17 AM
Lexs350's Avatar
Lexs350
So far everything works as advertised. All I reinstalled is the NAV/DVD unit. I have not reinstalled the vents nor wood trim yet. Making sure everything continues to work properly for the next few days.
When I update this post with LARGER RED TEXT later this evening, I would like to add the refrence post for the DIY for removing the trim and unit. Copy and Paste but not sure how to do that. Could anyone inform me how to do this. I am still a beginner when it comes to computers.
Thanks...Happy Thanksgiving you all
BTW. I took Eric's (from Beat-sonic) advise. I tucked the harness with the SLIDER SWITCH (NP-TV) underneath the dash where I grounded the black wire to the vehicle. Just leave the switch in TV mode. Then for the PUSH BOTTON switch, I mounted it on my steering column (RT SIDE) where a ignition key would go on most vehicles.
Old Nov 22, 2011 | 11:24 AM
Evil Teo's Avatar
Evil Teo
highlight what you want to copy. on the keyboard press ctrl and the letter C at the same time or hold down ctrl and press C either way thats the shortcut for copy. now for paste same thing hold ctrl or press it and hit the letter V.
Old Nov 22, 2011 | 11:27 AM
Evil Teo's Avatar
Evil Teo
mines just came in so, tomorrow i should be gettin it installed with help from a local friend.
Old Nov 22, 2011 | 11:32 AM
Lexs350's Avatar
Lexs350
Thanks EVO TEO I will try that later this evening.
Old Nov 22, 2011 | 12:04 PM
Evil Teo's Avatar
Evil Teo
looking at the diagram it looks like setting it to TV will bypass but will mess up ur location as well so we would have to reset it back to np. same thing with the nav bypass. hopefully we can get a clear understanding. can't we just leave it on TV and not engage the nav bypass. will that still cause the location to be off?
Old Nov 22, 2011 | 12:33 PM
Lexs350's Avatar
Lexs350
NAV works fine with switch left on TV. But I noticed from playing a DVD then going to NAV screen, I must exit DVD mode. ie FM RADIO or Satelite.
Old Nov 22, 2011 | 05:09 PM
WIZARD1325's Avatar
WIZARD1325
Mine just came in
http://www.flickr.com/photos/60908091@N05/6391469271/http://www.flickr.com/photos/60908091@N05/6391469271/ by http://www.flickr.com/people/60908091@N05/, on Flickr
Old Nov 22, 2011 | 05:20 PM
Lexs350's Avatar
Lexs350
Sure.....after I button up the job. ie. reinstall wood trim and upper vent. planning to finnish day after Thanksgiving, Friday.
Everything working fine. Had a DVD movie playing on the way home from work today. Picture AND AUDIO crystal clear...
Even made my first phone call while on the move.
Made the red letters larger in the original post....The best I can do. Hope this helps you all.
Again, Happy Thanksgiving to you all. Let's all keep the peace with our beloved family members so our friendly local POLICE department can have a safe thanksgiving day.
Peace out till after the holiday weekend.
Old Nov 22, 2011 | 05:30 PM
WIZARD1325's Avatar
WIZARD1325
OMG so illegal
Old Nov 23, 2011 | 01:06 PM
Evil Teo's Avatar
Evil Teo
where did u place the ground? got any pictures of that. I didn't take out the center part with the shift **** and the ash tray but i did cover them up so it wouldn't scratch. not sure why we need to remove it unless your planning to wire it through the ashtray.
