06+ gs350/gs430 brakes on 2gs
Old Nov 4, 2007 | 01:24 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
Sorry i havent been able to confirm this or not.. but they do appear to be similar to the LS430 design accept for one major point; on the LS430 calipers, the brake bolts that attatch the caliper to the hub are parallel with the car, while on the newer caliper design (GS350), the bolts are in the traditional location. I just need some time to do measurements and possibly even a test fit if i can our parts dept to order me a caliper. I wont be back to work until next friday, however, i have training in SoCal.
Old Nov 4, 2007 | 03:14 PM
rominl's Avatar
rominl
exclusive matchup
the caliper is not the problem, the attachment and brackets are the keys. the is300 and gs400/sc400/sc430 calipers look the same, but is300 brakes won't fit on others
Old Nov 4, 2007 | 03:34 PM
RTIS250's Avatar
RTIS250
CL Folding 500,000
The GS350/430 caliper is a one piece caliper like the supra's, so there is no bracket like on our factory 2GS brakes. I will do some more research when i get back and see if the mounting holes on the 3GS brakes lines up with the 2GS spindle. Im guessing they wont, but i will check it out.
Old Nov 4, 2007 | 04:20 PM
LexFather
Guest
Posts: n/a
THANKS!!!!!
Old Nov 4, 2007 | 09:26 PM
rominl's Avatar
rominl
exclusive matchup
ah icic. please do let us know if you find out more!
thanks!
Old Nov 6, 2007 | 05:50 AM
chuckb's Avatar
chuckb
does this mean Henry is getting a 2gen GS430?
Old Nov 6, 2007 | 05:56 AM
kit cat's Avatar
kit cat
about 600bucks just for brackets! ...then again, Nightpager makes really high quality products from what I have heard. Also, it only says "Lexus brakes" and doesn't specify if it's from a IS/GS/LS.
Nightpager
Old Nov 6, 2007 | 09:01 AM
rominl's Avatar
rominl
exclusive matchup
lol, a lot of things can happen for sure my beloved gs400 is getting a new home
thanks for the info, yuki! so i guess the brakes indeed don't fit
Old Nov 6, 2007 | 10:33 AM
kit cat's Avatar
kit cat
I think you should get another GS, you know you want to!
No prob Henry, I would assume it's not a direct bolt on like the Supra ones but all it says is that it uses "Lexus" ones...are the IS/GS/LS ones different (I hope they are considering the difference in size)?
Old Nov 6, 2007 | 11:12 AM
rominl's Avatar
rominl
exclusive matchup
maybe they already have all the variety for order as well, i assume the brackets won't be too different.
Old Nov 9, 2007 | 12:06 PM
kit cat's Avatar
kit cat
Henry, I guess that's for a 3GS from what I asked around 16 Aristo owners.
Old Nov 9, 2007 | 02:00 PM
rominl's Avatar
rominl
exclusive matchup
oh?! that's interesting, so it's for 3gs300 without the big brakes? all new 3gs have big brakes now, gs460 has larger rotors.
oh well, guess 2gs and 3gs brakes aren't really that freiendly to each other
Old Nov 10, 2007 | 12:32 PM
LexFather
Guest
Posts: n/a
Damnit.......thanks for trying gang!
Old Nov 13, 2007 | 11:04 AM
SoCalSC4's Avatar
SoCalSC4
Wouldn't it be easier to just use the tried-and-true Supra set-up?
No need to "reinvent the wheel..."
Sounds like a huge pain!
Loud1
Jun 22, 2011 06:26 PM
dk0515
Dec 28, 2009 02:35 PM
RNM GS3
Apr 17, 2009 05:17 AM
