The newb checklist.
Feel free to add to this thread. These are things the new SC owners should do as swiftly as possible to get the maximum enjoyment from their cars.
- SC repair manuals - 2 book set. Don't hesitate and think you'll get by. These are invaluable.
- Replace engine and transmission mounts. I don't care what your mileage is, do it and you'll instantly feel like you have a brand new car. Interior cabin noise and vibration reduced by 95% no matter what it is at right now. Your SC should be nearly silent while driving.
- Replace Control arm bushings. Another "just do it" as soon as possible. Nice tight steering and better control going down the road.
- BFI. A nice way to get a little extra punch.
- Replace shocks if they have over 50k on them and you'll enjoy the car 5 times more.
- Center drive shaft bearing and rubber driveshaft coupling. Have it inspected.
- Alternator and Power Steering pump. Have inspected for any air in the system or leaks and have the alt checked for output under load.
- GROUNDS. Clean ALL main grounds on the car all the way to the frame.
- Headlight and projector refinishing: https://www.clublexus.com/forums/sho...d.php?t=183023
Basic Tune-up/Oil Change
Plugs, Wires, Cap 'n' Rotor (non VVti).
Check all vacuum lines and replace if needed. Vac-Hose is cheap!!
Clean that engine!!! (look in the detailing forums) https://www.clublexus.com/forums/automotive-care-and-detailing-122/
A clean engine is a happy engine.
If you don't want to cough up the $200+ for the manuals, you can always get them online in PDF format. http://techinfo.toyota.com offers the full FSM for all Toyota and Lexus cars. It's a subscription site, with the lowest option being $10 for a 1-day, 24-hour access. With a broadband connection you can grab everything you need
Is your climate control LCD "broken"? There is now a site that sells replacement LCD screens for the climate control, but sodering is required. The face is not sold seperately by the dealership. But the cliamte control will still work regardless of LCD.
CD Changer giving "error"? Pre-97s do not have a memory buffer, so they might skip if going over bumps. If the cd changer displays error even with normal store-bought cds, then the laser probably needs alignment.
What is that slot to the right of my climate control and radio? Its the flipout cupholder. Its pretty much useless if you have it, since it pretty much spills your drinks when cornering.
What's the slot next to my shifter (a/t)? Its the shift override button if the car refuses to move the lever.
[Edit]: Fixed error
[Edit]: Fixed error
This was true up until about 6 months ago. Replacements LCD screens are available for 92-96 SC's from Lextreme. If you have some soldering skills it's about half the price of a refurbished unit and way cheaper than a new one from the dealership.
Last edited by O. L. T.; Oct 22, 2006 at 04:45 PM. Reason: removed advertising URL
You're right. And the LCDs are cheaper on ebay.
Last edited by O. L. T.; Oct 22, 2006 at 04:46 PM. Reason: removed advertising URL in quote
