DRLs
Old Jan 18, 2018 | 01:51 PM
daddiojigg's Avatar
daddiojigg
Default DRLs
Before you tell me to do a search; let me tell you i have.Obviously not successful.
Do all sc430's have DaytimeRunningLights? If not, what year-if any- did they start in?
Thankyou.
Old Jan 18, 2018 | 02:03 PM
Coleroad's Avatar
Coleroad
Yes they all have drl's .
Old Jan 18, 2018 | 02:05 PM
daddiojigg's Avatar
daddiojigg
Thankyou.All i could find were 2009&2010 brochures that mentioned it. Could not locate other years.
Old Jan 18, 2018 | 02:11 PM
Coleroad's Avatar
Coleroad
They can also be turned on or off by the dealer, or with techstream.
Old Jan 19, 2018 | 01:57 PM
GmanSC's Avatar
GmanSC
You can also add one, after you turned off the factory DRLs
Pretty bright
Old Jan 20, 2018 | 06:11 AM
mandyfig's Avatar
mandyfig
SC
IS
I tapped into an ignition ON source so it is on when the car is on.
Old Jan 22, 2018 | 12:39 PM
GTPMAGNA's Avatar
GTPMAGNA
GmanSC - like the look, can you tell me what after market lights to bought? I have tried a few different ones and each time they go bad because water has gotten into the housing of the LED lights.
Thanks
Old Jan 22, 2018 | 12:40 PM
GTPMAGNA's Avatar
GTPMAGNA
Mandyfig, same question. where did you get your lights?
Old Jan 22, 2018 | 03:20 PM
GmanSC's Avatar
GmanSC
They are called COB- They have no housing so no water could get into. They are so bright, much brighter than the foglights, so you can use them as one.
Mandy and I have the same lights. You can search this forum under “ my new drls installed”. All the infos are in there. Mandy can provide the link.
Old Jan 22, 2018 | 08:49 PM
StillLine's Avatar
StillLine
Default Still working great!
https://www.clublexus.com/forums/sc4...installed.html
I installed these COB DRLs 3.5 years ago and they still work great and look the same to this day.
StillLine
Old Jan 23, 2018 | 04:16 AM
daddiojigg's Avatar
daddiojigg
Default Forgive my ignorance
but why would you install these lights when all you have to do is turn them on with techstream(from what i understand) ? As well one of you say they are too bright for night travel, so what is the point other than to trick it out?
Thanks.
Old Jan 23, 2018 | 05:36 AM
GmanSC's Avatar
GmanSC
Thanks.
Simple. The OEM DRLs are yellow and ugly. Intalling the COB give the SC modern looks. I love the brightness, for safety reason, either driving at night or in the daylight.
Old Jan 23, 2018 | 01:22 PM
mandyfig's Avatar
mandyfig
StillLine
Love these, except can not install mine like this way since I have an older SC. No perfect location like yours, mine ended up in the grill.
kurama
Build Threads
Nov 17, 2024 03:56 PM
Searosis
Mar 16, 2019 09:46 PM
Boomin
Oct 15, 2018 11:07 AM
propcop
Aug 22, 2018 08:32 PM
MatthewH
Apr 4, 2018 01:15 PM
