DC SC430 Polyurethane Bushings
Old 05-19-17, 06:39 PM
lexus7217
lexus7217's Avatar
Default SC430 Polyurethane Bushings
Hello. I have poly bushings for the front suspension up for sale. These will fit 2002-2010 SC430. I purchased these and never installed on my 2006 SC430. Decided to keep it stock and replace with original rubber bushings. These are Daizen Polyurethane bushings purchased directly from TM Engineering.
Front Control Arm Bushing Kit $95.00
Services both left and right sides of the vehicle and contains upper, lower, and #2 lower arm bushings. Low durometer polyurethane replacement for worn OEM rubber bushings. Solves most irregular tire wear problems and highway speed driveability problems. Kit includes bushings and special synthetic grease.
Sway Bar Bushing Kit $25.00
Services both left and right, and front and rear of the vehicle. Very economically priced upgrade that noticeably improves handling - with no sway bar upgrade required! Uses existing OE brackets, sway bars and hardware. Permanent solution to worn rubber bushings. Direct replacement kit contains front and rear bushings, and special synthetic grease.
Steering Rack Bushing Kit $35.00
Direct replacement steering rack bushings eliminate twisting and movement of steering rack assembly. Easy installation does not require removal of steering rack or wheel/suspension re-alignment from existing specifications. Ideal solution for OEM or aftermarket rubber bushings which disintegrate when contaminated with residual motor oil or other contaminants - these are impervious to deterioration over time. Excellent upgrade alone or with other suspension upgrades!
PM if interested.
Thanks!
lexus7217 is offline
Old 05-22-17, 04:00 PM
texsexlex
texsexlex's Avatar
....interested in these & a pm has been sent
texsexlex is offline
bfigard
06-04-20 12:11 PM
farkas
08-26-11 12:25 PM
Kharizma
Suspension and Brakes
04-24-06 10:13 AM
nuocmam122
02-12-04 11:23 PM
Quick Reply: DC SC430 Polyurethane Bushings
