navigation problems
Old Oct 30, 2022 | 02:29 AM
jcorll's Avatar
jcorll
Default navigation problems
Hi first time here so here it goes! I purchased a 2005 SC430 with a replacement radio, Planet Audio model 9695B, back in August 2022. The radio works great but the navigation system does not work at all! Everything is black. I suspect that the wrong wire harness was used when the radio was installed but would like the navigation system, although old and out of date, to work as well. anyone have an idea as to what the problem might be or which wire harness I can use to fix the problem myself. Thanks Jef
Old Oct 30, 2022 | 04:54 AM
DJWLDW's Avatar
DJWLDW
Jeff
The Nav unit is easy to take out. Go on YouTube and search. Check your fuses first and if that is not the issue pull the unit and make sure everything got plugged back in after the radio install.
Dennis
Old Oct 30, 2022 | 07:57 AM
GmanSC's Avatar
GmanSC
I might be wrong but the radio and the NAV are independent. I do not think it’s the harnesses. Your problem could be as easier as just a fuse, if not, the NAV is toasted. You can buy the used NAV on EBAY.
Old Dec 31, 2022 | 11:09 AM
jcorll's Avatar
jcorll
took the center consul apart and found that someone had just disconnected the nav system. But alas, since lexus stopped supporting the nav system in 2015 I just left it unplugged and will use my cellphone if I need directions!
atl4love
GX - 1st Gen (2003-2009)
Jun 6, 2017 06:28 AM
grf118
14
May 18, 2012 07:12 PM
