pipe flange gasket
bank one is on the left side on all SC430 engines…
But I do know that the driver side has a leak but I guess I still did not get any error code for that. So question is should I still bother replacing the gasket or that little leak is not big deal provided I still do not have any error code for that.
Now time to focus on the passenger side. I did not find any leak form passenger side. Should I start with replacing the oxygen sensor?
Thank you so much
even if they were not, it doesn’t matter because bank 1 is always on the left regardless of the car make.
OBDII is a standard and all auto manufacturers agree to it.
Thank you so much
I have the P0420 & P0430 codes on my 2000 Firebird TransAm. I replaced the Bank 1 sensors 1&2 and it eliminated the P0420 code for about 3,000 miles, then it came back.
I know I need to build that smoke generator to run a smoke test on my exhaust but haven’t done it yet.
I certainly don’t want to buy new catalysts if I don’t have too…they are sooooooo expensive.
You could change both of the gaskets and see what happens.
I may do another exhaust leak test using soap/water spray technique and this time really focus on the passenger side where bank 2 is.
I have been fighting the notorious P0420 and P0430 for quite a while on my 2000 Pontiac Firebird TransAm LS1 5.7 V8. I changed my OEM bank 2 O2 sensors and it did get rid of the P0430 code for a few weeks but it came back…I used Denso O2 sensors to replace the OEM AC Delco.
the solution was a $7 Spark Plug nonfouler. Yep, this really works and it doesn’t matter if the cats are there or not, according to some on YouTube.
I found my $7 defoulers at Autozone.
this will work if you have a P0420 and/or P0430…if you have other emission codes, no guarantees…and,
YOU MUST HAVE FOUR OPERATIONAL O2 SENSORS.
All you need is one package of two nonfoulers, again $7.
you will need to drill out the nonfouler to make the O2 fit but DON’T drill all the way through like many youtube videos tell you…some suggest putting steel wool in the nonfouler but I didn’t because I thought it might rust, besides, the mod worked without steel wool.
NOTE: They tell you to drill all the way and then put the other nonfouler on the first, if you do this, it will be too long and you will need a 90 degree fitting…
you want to retain the small hole on the nonfouler…again, take it slow and DON’T drill all they way through.
drill a little at a time and keep test fitting until the sensor will bolt in the nonfouler.
reassemble, clear the codes and they won’t come back…
the idea is the nonfouler has the small hole and it moves the o2 sensor away from the main stream of the exhaust gasses.
this should work on any car regardless of the exhaust configuration…
this will NOT pass a sniffer
this will pass some emission tests
this may or may not pass a visual test.
Denso 02 Sensors
Denso 02 Sensors
Denso 02 Sensors
