Power Window Passenger Side not working
Old Oct 12, 2020 | 10:23 AM
LoriAnne's Avatar
LoriAnne
Default Power Window Passenger Side not working
My passenger side power window is not working. I have checked the fuse and it appears to be good. When I depress the power window switch, all I hear is clicking. How would I check to see if the power switch for the Passenger side is functional? Is there a way that I can determine if this is an arm problem or a motor issue without taking it into the dealer? Thanks
Old Oct 12, 2020 | 10:31 AM
Harold57's Avatar
Harold57
If you are hearing clicking, it sounds like the switch worked. It sounds like either there is a blockage or a worm gear is worn out. If you are handy, you can take the door apart to get to the mechanism. Check out a thread called something like "I found the source of the wind noise". The thread talks about replacing the weather stripping triangle at the front of the window but there are a few DIYs showing how to take the door apart to get to it. (If memory serves me well, there is one sometime after post #30 and somewhere between 10 and 30 posts later some more.) There is a diagram of the door in one of those posts.
Welcome to the forum.
Old Oct 12, 2020 | 10:40 AM
LoriAnne's Avatar
LoriAnne
Thank you Harold...I will look into it!
NickCaesar
Dec 21, 2020 06:12 AM
RockyTopGX
GX - 1st Gen (2003-2009)
Mar 10, 2020 11:29 AM
bruceb58
Nov 23, 2014 09:14 PM
EmpPenguin
Aug 9, 2013 06:23 AM
sj408
Apr 8, 2009 09:31 AM
