2004 sc430 starter replacement video/instructions
I have been searching all over the site and have been looking for a 2004 lexus sc430 starter replacement video or instructions. I have used search but havent found the lexus sc430 replacement instructions for the starter.
3 Attachment(s)
It’s a big job.... I would start by watching this YOU TUBE video FIRST
The job itself requires the removal of the intake manifold, which means disconnecting a whole lot of parts. It also gives you the opportunity to do some preventative maintenance too. Obviously you MUST order the correct gaskets/parts for the SC430 NOT the LS as in the video. I've also included the PDF on the starter components below. |
Many people also replace the knock sensors while they are in there. As Bob said, it is a BIG job to get the manifold off.
Why do you think your starter is bad? One good thing about the SC starter, it is known to be pretty reliable. I have been on the board for about 3 years and have only run across two people that had to replace their starter @Bon and someone else who recently changed their knock sensors due to mice |
