Tire Pressure warning
I have a 2004 SC430 with the recommended new (2,000 miles) tires on all four wheels. 245/40R18 Michelin Sport. Yesterday the tire pressure warning signal activated. I have check all four tires and set the PSI at 33. The lowest one was at 29 PSI and Highest 33 PSI.
The light remains ON. What am I missing or what is the problem? Bruce |
Originally Posted by btho1976
(Post 10622097)
Originally Posted by iolmaster
(Post 10622099)
If the sensors in the wheels have not been replaced, you likely have a battery going bad in one of the sensors. The only way to correct this is to replace the sensor. Batteries are not serviceable. If you decide to replace sensors, I would replace all of them at the same time.
Originally Posted by bumada
(Post 10622121)
I'm not too familiar with the SC430 but on my 4runner, there is a difference between a flashing TPMS light and a solid light. A solid light is low on air, a flashing light is a malfunction in the sensor (probably dead battery).
(Post 10622121)
Go to the sticky above for more infos. |
