Suspension Help
Old May 19, 2018 | 08:01 AM
bjhille's Avatar
bjhille
Default Suspension Help
My 2006 SC430 has about 130K miles on her and is in need of some TLC. I have already replaced a lot of the rear suspension with this kit from Figs (http://www.shopfigs.com/v3/by-vehicl...GAKIT_TRAC_TOE) with the MOTO-2-P option as this is for a daily driver. I have been very happy with this setup. I'll be putting this kit (http://www.shopfigs.com/v3/by-vehicl...GS-RUCA-HIGHHP) on at the same time I update the front-end
Fast forward to today and I am in need of refreshing the front end. I see figs has a kit for that (http://www.shopfigs.com/v3/by-vehicl...430-FR-REFRESH). I was going to get this, but was also wondering if I needed to replace the caster arm or bushing. In doing research on this site and asking Figs, all I have done is confuse myself. Is the caster arm the same thing as the lower control arm? Is this kit all I need? Are there more things I should consider outside of this kit?
Thanks for the help.
Old May 19, 2018 | 08:25 AM
MedicalDoc's Avatar
MedicalDoc
Caster arm is also known as lower control arm--LCA-- #2. In Lexulese is the lower suspension arm --LSA-- #2.
Old May 19, 2018 | 08:44 AM
bjhille's Avatar
bjhille
Okay, so by ordering the front-end refresh kit and getting the option lower control arms, I am replacing the caster arm/bushing. Thanks!
Next question, when I order the new lower control arms, do I spring for the poly bushings as well ($155 dollar add-on) or stick with what comes installed in the Mevotech arms?
Old May 26, 2018 | 10:13 PM
k7q's Avatar
k7q
Why order new caster arms? Why not just get the figs bushings pressed into your existing arms.
Old Nov 25, 2018 | 04:23 PM
jspringato's Avatar
jspringato
I installed the Generation 2 Castor Arm # 2 some time ago. I just ordered "front upper inner kit", SPF3161K, and "LWR ctrl arm bush kit", SPF4186XK. I ordered them believing these were bushings for the lower control arm and for the upper control arm. The Castor Arm bushing is shown as a seperate item on the master bushing kit list. The form lets you opt in and out for bushings you already have. Based on this, I don't think the castor arm bushings are the same as the lower control arm bushing. Am I missing something?
Old Nov 25, 2018 | 04:47 PM
jspringato's Avatar
jspringato
Originally Posted by 416tt
Both sides have 3 arms total.
1) Upper Control arm
2) Castor arm (lower 2nd control arm which connects to main lower arm)
3) main lower control arm
Attachment 374340
This answers it.
daniel6155
Suspension and Brakes
Jan 14, 2013 03:59 PM
Thomas17
Jan 28, 2010 10:03 AM
mad_trbo
GS - 1st Gen (1993-1997)
Nov 1, 2008 03:10 PM
