View Poll Results: How Do you apply White Lithium GRease to you top
Spray directly onto hinges
40.00%
Spray into cap , then apply with a Q-tip or similar applicator
0%
Use tube of grease and apply with Q-tip or similar applicator
60.00%
Voters: 5. You may not vote on this poll
Convertable Top Maintenace
Old Apr 10, 2018 | 01:02 PM
AustinTex's Avatar
AustinTex
Thumbs up Convertable Top Maintenace
After searching this forum , it looks like the consensus is to use White Lithium Grease to lube the moving parts and 303 protectant on the rubber seals
In the below video the guy sprays white lithium in a cap and then uses a Qtip to apply it to the hinges. It just doesn't appear to get enough on the hinges.
Are most of you buying a tube and applying it with a q tip , spraying directly to hinges, or spraying into the cap and then using a q tip?
+ or or
Permatex has a non staining lithium grease that is reported to be odorless
https://www.amazon.com/Permatex-80345-White-Lithium-Grease/dp/B000HBNV58/ref=sr_1_fkmr1_3?ie=UTF8&qid=1523391773&sr=8-3-fkmr1&keywords=white+lithium+grease+non+staining https://www.amazon.com/Permatex-80345-White-Lithium-Grease/dp/B000HBNV58/ref=sr_1_fkmr1_3?ie=UTF8&qid=1523391773&sr=8-3-fkmr1&keywords=white+lithium+grease+non+staining
Permatex 80345 White Lithium Grease, 1.5 oz.
Old Apr 10, 2018 | 03:18 PM
Caflashbob's Avatar
Caflashbob
Lithium grease used to be water soluble.
S2000toIS350
LFA Model (2012)
Sep 21, 2018 03:03 PM
MarkiAlex
Jan 19, 2016 03:06 PM
JessePS
Jun 29, 2009 04:32 PM
L&E
Nov 19, 2008 08:26 PM
