Replacement flex cables for our climate controls
Old Mar 13, 2018 | 12:47 AM
Retroplay's Avatar
Retroplay
Default Replacement flex cables for our climate controls
So, I have been messing about with climate controls recently, and after encountering several broken flex cables, I finally looked up replacement parts and thought others might benefit from it.
It is a 100MM, 1MM pitch, 12 conductor FPC cable with same side contacts. Wurth sells these through Mouser for $3.80 a piece. The climate control uses two of them.
https://www.mouser.com/ProductDetail/710-686612100001
This is the flex cable that goes between the main board and the front panel of the climate control. You can get a Molex version at 127MM for $1.99 a piece.
https://www.mouser.com/ProductDetail...84%252bw%3d%3d
I haven't ordered them yet, but an FPC is an FPC is an FPC.
Old Mar 13, 2018 | 12:50 AM
Retroplay's Avatar
Retroplay
The longer version, despite being cheaper might actually help reduce the stress on these cables a bit so they last longer.
Old Mar 13, 2018 | 10:32 AM
Harold57's Avatar
Harold57
Good to know, thanks Retroplay
Old Mar 15, 2018 | 04:00 AM
Retroplay's Avatar
Retroplay
I have ordered some of the 127MM cables for an upcoming project. I will let you all know how they work out.
Old Mar 19, 2018 | 01:49 PM
Retroplay's Avatar
Retroplay
Perfect replacement. They are a little more flexible than the OEM cables, but that is probably a good thing. The stiffness is probably why they crack. This is the 127MM version. The extra length should help reduce stress on the cables as well.
Old Aug 15, 2023 | 04:30 PM
Mariya1's Avatar
Mariya1
10th Gear
Retroplay
Thankyou Thankyou Thankyou for the link!!!! You are truely God sent!!!! I've been trying to figure out which cable is the right one for the last week!!!
rbigshow04
Feb 15, 2010 03:55 PM
skotter
Mar 20, 2009 01:53 PM
STRONG SC
SC400 / 300 Classifieds
Feb 23, 2006 06:19 PM
