brakes buzzing
Old Oct 12, 2017 | 08:46 AM
jabbis7237's Avatar
jabbis7237
Default brakes buzzing
when i put on the brakes at slow speed i hear a buzzing noise and the brake pedal pulses
Old Oct 12, 2017 | 11:20 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
ABS is activating. Any work performed on your car recently?
Old Oct 12, 2017 | 11:49 AM
jabbis7237's Avatar
jabbis7237
no work done, it just started a week ago
Old Oct 12, 2017 | 01:07 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
any dash lights?
is the brake fluid level okay?
what year and how many miles?
when you say slow speed, do you mean like 5-10mph?
i had that issue after some front end work.
the ABS sensor had grease on it. One bolt holds it in place. I wiped it off and disconnected the battery...all has been good since that time.
Old Oct 12, 2017 | 01:52 PM
jabbis7237's Avatar
jabbis7237
I have VSC/VSC off lights on the brake fluid is good and the car has 155K miles on it. Yes slow speeds under 10mph
Old Oct 13, 2017 | 02:03 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
try disconnecting the battery for five minutes...
slikcat
Suspension and Brakes
Aug 29, 2024 08:38 PM
kpielmeier
Nov 17, 2018 06:51 PM
Mantasv94
Nov 14, 2018 08:55 AM
SNiiP3R
Oct 13, 2018 07:33 AM
xbladex00
May 7, 2015 02:10 PM
