Techstream TIS with SC430 - Key and TPMS Programming
Old May 8, 2021 | 10:37 AM
  #46
jimisbell's Avatar
jimisbell
1) Will this work on my 2004 LS as well as the 2006 SC? Or niether?
2) I cannot get the links to amazon to work, are there newer links?
3) Is there a version for Linux or will I have to get a Windoze computer just for this?
4) In AliExpress there are many of them with different software numbers. How do you know which one to get?
Old May 8, 2021 | 10:55 AM
  #47
DJWLDW's Avatar
DJWLDW
Jim
Here is a good thread to review and yes it will work your LS as it does on mine. It is a Windows XP based software so no it will not work on Linux. The only version I know to stay away from is V13. I am running V12 on my laptop and my son has V15 on his.
Tech Stream Software Cable ver 2.0.4 - ClubLexus - Lexus Forum Discussion
Dennis
Old May 8, 2021 | 06:16 PM
  #48
jimisbell's Avatar
jimisbell
I ordered this one on EBay
https://www.ebay.com/itm/12469237272...53.m2749.l2649
Hope its the right one. I dont understand the two circuit bords that are pictured but thats OK if it works.
Old May 8, 2021 | 06:55 PM
  #49
DJWLDW's Avatar
DJWLDW
Jim
You do realize that is being shipped out of China so it could be a few weeks or so before you receive it.
Dennis
Old May 8, 2021 | 10:07 PM
  #50
jimisbell's Avatar
jimisbell
Both cars are running fine right now so I am not worried....and I have the Sky Redline for backup if both went down........and a harem of widows that will carry me anywhere.LOL
Old May 9, 2021 | 04:58 AM
  #51
DJWLDW's Avatar
DJWLDW
Jim
That will give you time to round up an old Windows XP Laptop.
Dennis
Old May 9, 2021 | 05:18 AM
  #52
iolmaster's Avatar
iolmaster
You do realize that is firmware version 1 not 2. My 06 would not work with version 1. Hope yours does. Also, as discussed before, Windows 10 32 bit works fine on a newer computer. It may be hard to find an XP.
Old May 9, 2021 | 06:36 AM
  #53
Oldsig's Avatar
Oldsig
The v15 with a 1.4 cable are working correctly with my '06 on a Win7 computer. With that same cable and computer, the v12 and v14 Techstream would not connect to my '06.
Bob
Old May 9, 2021 | 07:33 AM
  #54
iolmaster's Avatar
iolmaster
Bob
I know, the results are all over the board. Sometimes I think it is just the luck of the draw.
Old May 9, 2021 | 07:46 AM
  #55
jimisbell's Avatar
jimisbell
well, at least I got it from Ebay so I can return it if its not right. Usually I buy from AliExpress..direct from China, but this time I decided to play it safe because the price was only a few dollars different.
Old May 9, 2021 | 05:52 PM
  #56
frankymenz's Avatar
frankymenz
I’m running version 12, I originally had just the 1.4.1 cable off eBay, it worked perfectly on my 2000 Avalon. It wouldn’t read live engine data on my 2014 ES350, it could set/customize options and program keys. I purchased a 2.0.4 from aliexpress for a much better price Than amazon or eBay., 37 usd. This version firmware reads live engine and transmission data. I currently possess both cables, 1.4.1 and 2.0.4, so I’m capable of trying both cables, I’m able to repair up to 2018, I may get version 14 or 15 one of these days.
Old May 9, 2021 | 06:01 PM
  #57
GmanSC's Avatar
GmanSC
I do hope everything will go well for you. Installing TechStream sometimes can be a challenge. Do come back here if you run into problem, we can help. Once you get it going, you will like it. Good luck.
Old May 10, 2021 | 03:54 PM
  #58
Oldsig's Avatar
Oldsig
It certainly looks that way doesn't it... I read an article from a company that sells Techstream and the cables. They said to keep trying different Techstream versions until you find one that works for you...wow
Old May 10, 2021 | 04:06 PM
  #59
Oldsig's Avatar
Oldsig
Originally Posted by GmanSC
Bob, you can not delete ALL the keys. You will need a master key to delete the keys and you can not delete the master key itself. So you always will have at least one working key. As I understand, you can programmed and designate two master keys, anything after that will be designated as sub keys. You can have total 4 keys in the system.
That was a late night post and being too tired to power up my Techstream computer and connect it to see what's on the immobilizer screen
I was hoping to hear it would list the master keys plus the valet and wallet keys so I could select what I wanted to delete to free up a spot for the new key.
I finally looked... As you folks know that's not one of the option...I now have a plan though.
Bob
C-COOP
Nov 7, 2014 02:49 PM
mctuners
Jul 29, 2009 11:01 AM
MJMerlina
Apr 10, 2007 06:55 AM
