Problem with tyre pressure warning system
Old Feb 26, 2003 | 12:12 PM
MJB's Avatar
MJB
Default Problem with tyre pressure warning system
Hi again,
I had a flat tyre problem recently (see post about 'fusing valves caps' earlier). This resulted in the 'low pressure' warning going off - beeping at me every 5 minutes.
I was unable to take the car into a dealer and had to resort to sending the offending wheel in by courier to be re-valved.
When the wheel came came back I fitted it and, surprise surprise, the low pressure warning is still beeping at me every 5 minutes.
The system clearly can't 'see' that the tyre with its new valve is now at the correct pressure. Once the warning starts going... it keeps going!
Does anyone know if re-setting the pressure warning system is a job I can do myself, or do I have to get the car all the way into a dealer just for that (which would be a big pain!)?
Thanks for any advice.
Martin
(P.S. beginning to wish I'd waited six months instead of getting a Japanese import so I could beat everyone to it! At least these things would be under warranty....)
Old Feb 26, 2003 | 12:48 PM
RodF's Avatar
RodF
Martin -
When I removed my sensors, I had the same issue - wouldn't stop beeping.
I had to take it to the dealer. It literally took him 5 minutes to hook up his computer and reset it. Problem was solved.
Old Feb 26, 2003 | 01:32 PM
MJB's Avatar
MJB
Thanks Rod,
I had a feeling that would be the case. I just hoped to avoid it as it takes a whole day to get my car to the nearest service dealer and back again!
Not many things you can do yourself on these fancy cars, eh?
Old Feb 26, 2003 | 02:56 PM
RodF's Avatar
RodF
Not in this computer-driven age. Maybe someone here knows if disconnecting the battery and reconnecting it would reset the system. I didn't think of trying that.
Fizzboy7
Jul 3, 2012 05:46 AM
DaveJ
Apr 20, 2007 02:22 PM
9520G
Oct 18, 2006 11:42 AM
mtlis250
Dec 14, 2005 06:43 PM
advancer
Mar 11, 2004 08:56 PM
