Roof opens only intermittently
Old Sep 13, 2018 | 05:50 AM
  #31
Bgw70's Avatar
Bgw70
Veteran: Air Force
Originally Posted by sc07
Update: fixed the problem through team work between a good friend at Toyota who kindly helped with tech stream, got the code B2523. And charismatic neighbour who happens to have extensive connection among dealership, sourced me the part and got it installed at Lexus.
Thanks PO Dan for replying my private message, and thanks all for contributing
please post the link to the other thread, it will make this thread much more helpful to a future user with a problem.
Old Sep 15, 2018 | 07:50 PM
  #32
sc07's Avatar
sc07
the other thread is at:
https://www.clublexus.com/forums/sc4...lp-please.html
Old Sep 17, 2018 | 11:34 AM
  #33
DshngDaryl's Avatar
DshngDaryl
His post is on this forum, and actually on his post he borrowed your pictures of trim pieces taken off the trunk
Thanks for taking the time to find the original post. It was very interesting to see who was on ClubLexus back then and who is here now
I have to laugh at your statement. I stole HIS picture, instead of the other way around. All the stuff I post about roofs was stuff I had found trying to fix my own top. I just stuck it all into a folder on my computer and regurgitate it when it is needed.
Old Sep 17, 2018 | 11:48 AM
  #34
Bgw70's Avatar
Bgw70
Veteran: Air Force
i am not looking forward to the day when I know as much about the roof as you!
it may be coming sooner than later, because the 2002 is beginning to make a new sound when the roof is raised and lowered.
it will be top down weather soon, that’s when I will start looking into it more.
i still need to replace the HVAC servo Motors in the dash.
Old Apr 15, 2019 | 12:28 PM
  #35
nomods4me's Avatar
nomods4me
Default if the roof is making noise
(like mine is) then it's probably time to lube it
trouble is I can't find the places to spray the lube
Old Jul 3, 2022 | 09:35 PM
  #36
RA92525's Avatar
RA92525
10th Gear
I’m back to report that the code shows: B2523 Limit switch (Roof position No.1) malfunction.
As far as the research goes, roof position switch No.1 & No.2 are integrated into a single part, the part number is 84742-24050. And my car is 2007. Can anyone confirm if this is the correct part before I place the order? Thanks.
Sc07, so is the part number 84742-24050 for that switch? Same issue here and I like to order. Thanks
Old Jul 4, 2022 | 08:34 AM
  #37
Raven01750's Avatar
Raven01750
Yes. That is the right part according to Longo Lexus.
https://parts.longolexus.com/
There are many sites like this that have diagrams etc. to help you make sure you are ordering the right parts. Good luck.
Paul
TCrespi
Jun 27, 2024 02:15 PM
kellydon09
RX - 1st Gen (1999-2003)
Nov 4, 2017 09:52 PM
grottoman
Dec 1, 2014 08:12 PM
ShinySC
May 18, 2011 08:51 AM
itsZep
GX - 1st Gen (2003-2009)
Dec 3, 2007 06:17 AM
