LuxLink Question
Old Jan 23, 2014 | 08:26 PM
mrblister's Avatar
mrblister
Originally Posted by ShawnOk
MrBlister, Right now I'm using just the transponder chip from the wallet key (which actually broke in my wallet). Do you think changing it out for an actual OEM Lexus key would help? That's what the tech suggested for $75 (once I have the extra original keys mailed to me).
I took my wallet plastic case cut it in half placed the piece of plastic that had the chip in it and then wrapped the ribbon cable around it and put it in the immobilizer box . Then ran the black antenna wire up and around the ignition switch and fished it around it with the dash trim ring off . The chip works fine from the wallet key and this way you don't have to leave a valet key in that box which could lead to a theft of your car If someone knew it was there. The wallet key has to be cut in half so it will fit into the immobilizer box
Old Jan 25, 2014 | 03:17 PM
ShawnOk's Avatar
ShawnOk
As MrBlister suggested I pulled of the trim piece and found the black antennae wire wrapped around the ignition column. I rewrapped it in the opposite direction and for today (at least) I haven't had any problems. Car has started with every attempt. Fingers crossed! Thanks for all the advice everyone!
Old Feb 19, 2014 | 10:14 AM
mrblister's Avatar
mrblister
So did that fix your problem ??
Old Feb 19, 2014 | 02:55 PM
ShawnOk's Avatar
ShawnOk
Yup, still no problems! Starts every time now! Easiest fix... local shop wanted to charge $75 diagnostic fee for something that simple. Unbelievable.
Old Feb 19, 2014 | 03:15 PM
mrblister's Avatar
mrblister
That's great glad it worked out for you.
Old Feb 19, 2014 | 03:18 PM
ShawnOk's Avatar
ShawnOk
Wouldn't have been able to even know where to start this simple fix without help from this forum and experts like you. While money hungry shops would have charged to even take a look. Thanks again, everyone!
Old Feb 19, 2014 | 03:29 PM
mrblister's Avatar
mrblister
Einstein said "we all stand a little taller when we stand on the shoulders of others "
tofuprod
Jan 28, 2019 06:58 AM
LVFlier
Aug 4, 2018 05:09 PM
LVFlier
Jan 18, 2018 11:20 AM
prosales72
Hybrid Technology
38
Feb 13, 2016 04:14 PM
Allen K
Jan 26, 2016 11:37 AM
