Rim Question
Old May 21, 2013 | 08:58 PM
bjhille's Avatar
bjhille
Thanks Thimbiz, I didn't see that post before.
Is this going to be the case for all 17 Lexus rims? I was hoping to find a factory set of 17" that would bolt-on with no spacers, but with the proper snow tires, fill the wheel well as a stock 18" rim would (don't want the flush look or anything like that). I thought the IS lines might fit that bill, do you know if the GS ones will.
I going to go searching again. This offset thing drives me nuts.
Old May 22, 2013 | 07:54 AM
kjcole's Avatar
kjcole
Spacers can make this work, but just be sure you get meticulous balancing. I really like the RoadForce system. Those are nice rims.
Old May 24, 2013 | 04:12 PM
bjhille's Avatar
bjhille
I stopped by a tire shop this afternoon and found that the is300 rims I was looking at had the same offset as the stock SC430 rims. So, fitment shouldn't be a problem.
I called tirerack to see what size tire they recommend. They said that due to the weight of the car, they recommended a 17" rim (17x7.5-8) running 235/45/r17 tires. The rims I was looking at are 17x7 so he said those would need 225/55/r17 tires but was concerned it wouldn't clear my wheel wells.
So, I searched this form to see what others are running on their 17" snow tires. It looks like some Lexus dealers in Canada was selling a cold weather package that ran 235/55r16 tires. Am I correct that 235/55r16 and 235/55r17 tires are the same physical size other than the "cutout" for the rim? In other words, if a 235/55r16 works on this car, shouldn't a 235/55r17 tire work just as well (obvious difference of a 16inch rim vs a 17inch rim)?
Thanks again for all your help. I'm hoping to get this cleared up soon.
Brian
Old May 24, 2013 | 04:43 PM
thombiz's Avatar
thombiz
I have Michelin MXV4 225/55/17 on our SC430 and no clearance problems at all. I think the speedometer is off about 2 mph at 60. It reads 60 mph but we're really doing 62 mph.
Old May 24, 2013 | 07:16 PM
Prasha's Avatar
Prasha
Brian
I think if the aspect ratio is the same, the total diameter of the tire would have 2" difference. The speedometer will read lot differently. Go with thombiz suggestion.
Old May 25, 2013 | 06:42 PM
jzwu's Avatar
jzwu
I think it is off by 1 inch.
goldhouse
Suspension and Brakes
Jul 8, 2018 06:17 PM
myronl
IS - 1st Gen (2001-2005)
Nov 12, 2007 10:29 PM
hiwind
Wheels, Tires & Brakes Forum
Mar 28, 2005 10:39 PM
fierce gs
Sep 26, 2001 09:28 AM
