Another question about LuxLink please
Hi all,
I have connected all the wires of the LuxLink units. And here are my results and my questions also:
1- I press the unlock botton till I hear a beeb then I press look botton twice..the engine starts then the roof opens.
2- I press the unlock botton till a beeb comes the I release .. the roof opens withtbe engine starting.
3- when roof is down...I press the driver window botton 3 times...rear windows gose up. If I press again the same botton 3 times, it goes down but immediately goes up again !!! My question, is this normal?
Waiting for your comments
Thank you all
Thank you all
The correct sequence is as follows
PRESS UNLOCK LOCK LOCK [ MOTOR STARTS ]
PRESS UNLOCK HOLD TILL BEEP THEN QUICKLY PRESS LOCK LOCK MOTOR STARTS AND TOP GOES DOWN OR UP DEPENDING ON WHERE THE TOP WAS UP OR DOWN ][ THIS IS TIME SENSITIVE SO YOU HAVE TO BE SURE OF A SOLID PRESS THEN ANOTHER SOLID PRESS IN A SHORT SPACE OF TIME ]
PRESS UNLOCK HOLD TILL BEEP WHEN WINDOWS START DOWN OR UP PRESS LOCK ONCE ONLY TOP WILL GO UP OR DOWN CAR FRONT WINDOWS DOWN . PRESS DRIVERS SIDE WINDOW BUTTON 3 TIMES [ LISTEN CARFULLY BETWEEN PRESS AND YOU CAN HEAR THE RELAY CLICK EACH TIME YOU PRESS THE DOWN BUTTON ]. THE REAR WINDOWS WILL GO DOWN OR UP DEPENDING ON WHERE THEY WERE. THE WINDOW PRESSES DOES CONFUSE THE CARS COMPUTER SO IF YOU TRYED TO OPPERATE TOP AND IT WONT WORK UNTILL YOU SHUT CAR OFF AND THEN RESTART. THIS IS A KNOWN FAULT HAS NOTHING TO DO WITH LUXLINK ITS THE CARS COMPUTER DISABLING THE TOP BECAUSE IT THINKS THERE IS AN ERROR.[ IF YOUR 1/4 WINDOWS ARE GOING DOWN THEN UP THERE IS A IMPROPER WIRING ISSUE. THE 1/4 WINDOW MOD IS NOT A SMART DEVICE IN THAT IT DOES NOT KNOW IF THE WINDOWS ARE UP OR DOWN . SO IF THE DONT MOVE ON THE FIRST SET OF TRIPPLE PREESES WAIT 20 SECONDS THEN TRY AGAIN. REMEMBER THE 1/4 WINDOWS DO NOT MOVE DOWN OR UP AT THE SAME TIME . YOU WILL SEE ONE WINDOW MOVE THEN THE OTHER WILL MOVE. THIS I BELIEVE WAS DONE TO PREVENT OVERLAODING THE WINDOW CIRCUIT
IF YOU DOUBLE PRESS THE TOP BUTTON ON DASH THE TOP WILL GO DOWN IN ONE MOTION YOU DONT HAVE TO HOLD THE BUTTON AND IF THE TOP IS DOWN ALLREADY DOUBLE PRESS THE DASH BUTTON AND THE TOP GOES UP.
IF YOU ARE PARKING CAR AND TOP IS DOWN BEFORE YOU TURN OFF ENGINE AND BEFORE YOU OPEN THE DOOR IF YOU DOUBLE PRESS THE DASH BUTTON THE TOP WILL START TO RISE. TURN KEY OFF IN IGNITION AND REMOVE IT. MOTOR WILL CONTINUE TO RUN OPEN CAR DOOR EXIT LOCK THE DOOR MANUALLY AS YOU LEAVE TOP WILL COMPLETE ITS CYCLE AND CLOSE AND THE MOTOR WILL AUTOMATICALLY TURN OFF.
I will try all of your instructions and report back my findings.
I really appreciate you support . Many thanks to you.
