HELP! Alignment Signup Or Not!
Old Mar 31, 2016 | 06:06 AM
sixonemale's Avatar
sixonemale
Originally Posted by Slingshot1
Hi John
If they align it to Lexus specs you will still have inside tire wear, I would ask if they will align it to any spec (not Lexus, some shops says they have to follow manufactures specs), if they will do that, tell them to take all of the negative camber out that they can. If they get each tire down close to -.5 degrees your tire wear will be much more even and performance will not be degraded unless you are on the track a lot. If they align it to Lexus specs all your lifetime balances will still cause inside tire wear!
Good luck
Mike
Good advice Mike. I had this done long ago to get rid of the inner tire wear problem that SC's have. Since having it aligned properly, at least what I consider properly, no more inner tire wear problems.
Old Apr 3, 2016 | 11:26 AM
CBXMAN's Avatar
CBXMAN
Use this link to find a shop near you that can do Road Force Tire Balancing. Hunter is the name of the company that makes this machine. Highly recommended!
http://www.hunter.com/gsp9700
Old Apr 3, 2016 | 05:50 PM
rudyH's Avatar
rudyH
That is a great deal but I really suggest you read it over carefully, as boring as that may be. I wouldn't go by verbal explanations of features. I'm not saying they're pulling any funny business, but it can't be as simple as get an alignment when you think you need one. I'm just an old guy that's been burned by MY OWN FAILURE to understand fully what I was buying.
Old Apr 3, 2016 | 05:58 PM
Coleroad's Avatar
Coleroad
The original post here from the op is more than four years old. The ones I have seen since have limits like your saying.
Old Apr 4, 2016 | 02:27 PM
rudyH's Avatar
rudyH
Oops. It popped up as new when I logged in. Sorry to waste the bandwidth.
Old Apr 5, 2016 | 11:56 AM
1supra's Avatar
1supra
does this kinda tire balancer make much diff? ive never had issue with balancing,always alignment
Chazzer96
Feb 26, 2019 07:22 PM
PhantomV
Oct 13, 2014 11:43 AM
Darkmanx85
IS - 1st Gen (2001-2005)
Jul 26, 2009 07:01 PM
kjbro
Jul 22, 2004 03:35 PM
