what is the wheel bolt pattern on SC430?
They're the same. Here's a site with a database of wheel bolt patterns where you can search. http://www.roadkillcustoms.com/hot-r...&StudSpreadMM=
Hi
in looking around, I found at least one wheel with the same tire size, but bolt pattern was 5x100 instead of 114. Would a spacer work, or is that dangerous. I also found Mitsub. Starion using 145 70R 18, 5X114.3 (is that .3 different)? Is there something wrong, other than bigger size, in using this 18" tire/wheel?
