The BIG Maintenance...
Old Feb 24, 2011 | 06:12 AM
PLAYTYM's Avatar
PLAYTYM
Exclamation The BIG Maintenance...
Timing Belt Change and Other Important Maintenance!
(Prices and Part Numbers)
1. Drive Belt – Part Number SC4DB02 $39.24
2. Engine Air Filter – Part Number 1780150060 $22.18
3. Oil Filter – Part Number 90915YZZD3 $3.99
4. Cabin Air Filter – Part Number 87139YZZ01 $22.88
5. GL-5 Gear Oil – Part Number 0888502506 $24.66
6. Oil Drain Plug Crush Gasket – Part Number 9043012031PC $0.85
7. Rear Differential Crush Gasket – Part Number 1215710010 $0.91
8. Timing Belt and Water Pump Kit –Part Number SC4TB02 $291.50
9. Timing Belt Tensioner Assembly – Part Number 1354050030 $38.00
10. Thermostat – Part Number 9091603100 $15.67
TOTAL = $459.88
All the prices and part numbers listed are from www.sewellpartsonline.com and reflect the CL discount!
Hope this helps,
Josh
Old Feb 24, 2011 | 06:49 AM
grabber2's Avatar
grabber2
My local dealership Bay Ridge Lexus quote me $1,850 for the 85K/90K maintenance.......
Old Feb 24, 2011 | 07:17 AM
PLAYTYM's Avatar
PLAYTYM
That's a pretty normal quote and I doubt will include all of the above.
However the parts and prices I have listed above are for the maintenance I will peform myself on my SC430 this spring.
Old Feb 24, 2011 | 03:59 PM
huy33's Avatar
huy33
Holy cow!!!! I guess I better start saving now.
Old Feb 24, 2011 | 04:24 PM
scdroptop's Avatar
scdroptop
The Toyota Type IV ATF is like $120 for a full flush and refill, isn't it? I have the invoice somewhere...it takes a lot of fluid.
Also I would go ahead and look at brake pads, turning rotors and bleeding the brakes, draining and filling the p/s fluid too while you are at it.
What about fuel filter? Plugs? Clean intake..remove carbon build up and install injen?
Just some other ideas.
Old Feb 24, 2011 | 05:16 PM
Pnuge88's Avatar
Pnuge88
Dont forget about the seals and waterpump. You might as well
Old Feb 24, 2011 | 08:09 PM
grabber2's Avatar
grabber2
The quote for $1850 include timming belt, water pump, & the rest 90K maintenance......Bay Ridge Lexus won;t just do the timming belt alone & states it must be done as a whole package inorder for them to guarantee their service/job.
Old Feb 25, 2011 | 06:58 AM
PLAYTYM's Avatar
PLAYTYM
I got a quote for $170.00 for an ATF flush, filter, and fill. Well worth it!
Plan on looking at the pads and rotors and may swap-out for drilled and slotted/w ceramic pads. Don't think I'll do much with the p/s fluid or p/b fluid as flushing all that out can cause more issues with busting lines and simply not needed with the mileage it has. The car has been in a garage in Florida it's whole life.
Fuel filter makes perfect sense though...need to add that to my list!
Thanks for your input!
Old Feb 25, 2011 | 07:12 AM
tentoys's Avatar
tentoys
I asked about changing the fuel filter on my 99 Land Cruiser at my local toyota dealership and they told me toyotas use lifetime filters.I would expect lexus is the same.
Old Feb 25, 2011 | 07:31 AM
PLAYTYM's Avatar
PLAYTYM
I will check into that, thanks!
Old Feb 25, 2011 | 07:39 AM
PLAYTYM's Avatar
PLAYTYM
BTW...how do you tliek your Yoko S-Drives? I'm putting a set of tourmalines on this summer with Yoko S-Drives and was curious about their ride and tread-wear?
Old Feb 25, 2011 | 10:45 AM
JerryB's Avatar
JerryB
Hi grabber,
This type of horse puckey is why I go to an independent shop.
Jerry Baumchen
Old Feb 25, 2011 | 01:22 PM
scdroptop's Avatar
scdroptop
I love them...I had dunlop direzzos on my first SC with the 20" staggered setup and they cupped prematurely (with alignment/rotate/balance in spec) as well as had dry rot. I believe they were sitting in a warehouse far too long before they were shipped. Always buy FRESH tires!! The Yokos beat the hell out of those flinstone rock tires called RFT's they give us though!
Old Feb 28, 2011 | 07:10 AM
PLAYTYM's Avatar
PLAYTYM
I can't wait till this spring! I have so much going on with my 9 year old! She's getting all her scheduled maintenance performed by me, which should bring her up to date for the next six years. She's getting new Tourmalines and S Drive tires. She's also getting LuxLink to top it off. She's got 56,000 miles on her now and hope to keep her for the next four years, which should put her at about 100,000 or less for mileage. At that point I will sell her, and hopefully buy a 2010 with low miles and keep that one forever!
Old Feb 28, 2011 | 11:00 AM
neilsix's Avatar
neilsix
I got an estimate from my independent shop for $1,150 (with ATF flush) over here in LA. Is the Lexus dealer that much more dependable than going to an independent shop? Since I'm a fairly new SC430 owner who hasn't done the major maintenance yet, so would love to get input on that.
