Rust!!
Old Nov 10, 2008 | 07:36 PM
Bellex's Avatar
Bellex
Default Rust!!
Looking at an 02 SC430
noticed a small amount of rust on the corner of the trunk (very close to the tail-light) - common problem??
Old Nov 10, 2008 | 07:39 PM
Bellex's Avatar
Bellex
And by the tail light I mean the point of the trunk (at the top of the tail-light)
Old Nov 10, 2008 | 08:10 PM
Habious's Avatar
Habious
Yup, I have the exact same thing...and I've seen it also on a fellow CL member's 2002 SC430.
Old Nov 10, 2008 | 10:30 PM
Bellex's Avatar
Bellex
worried about it spreading! is this a deal killer?
Old Nov 11, 2008 | 07:55 AM
intdiamond's Avatar
intdiamond
My '02 has it too. It's from rubbing when the top goes up/down... every year I sand the spots carefully, dab w/primer, touch up paint, and clear-coat. It hasn't spread at all; just wears on the same spot. There's actually a couple spots around the tail-light area where it happens on mine; the spot you saw is the largest, and there's a couple much smaller ones if you open the trunk and look around the edges of the tail-light area. You can also take off the upper reflector (the part of the tail-light that's connected to the trunk) with two 10mm screws and get at the spots easier.
Unless they're real bad, I wouldn't let it sway your purchase. You just have to take care of those areas with a small amount of maintenance and not worry about it.
Old Nov 11, 2008 | 09:00 PM
Peter_Klim's Avatar
Peter_Klim
Rust? I thought the body of the SC was made of aluminum?
marty99
Oct 4, 2013 11:26 AM
dag8882
May 8, 2011 01:43 PM
Sgtnapsc43
Apr 18, 2011 02:42 AM
Lou Fishma
Jul 26, 2007 07:12 PM
Deanski
May 2, 2004 06:35 AM
