NavTool Video Interface Unit Group Buy
Old 11-08-08, 07:22 AM
ynctypes
ynctypes's Avatar
Thumbs up NavTool Video Interface Unit Group Buy
Hi All,
Just want to let those that don't know, NavTool is offering a group buy on their video interface unit, we could get it for as low as $135, if there are 19 more people... see link below:
https://www.clublexus.com/forums/sho...d.php?t=388353
Old 11-13-08, 07:29 AM
bigmalik00
bigmalik00's Avatar
I am in MD too. who are you getting to do the install?
Old 11-13-08, 08:23 AM
Habious
Habious's Avatar
It's not too bad. I put mine in. Hardest part was installing the backup camera. The Navtool module itself isn't bad...one pigtail connector, a group of ground wires, a switched 12V+, and a reverse-sensor lead.
Old 11-13-08, 10:28 PM
moomoo
moomoo's Avatar
this unit will be plug in the trunk next to the nav unit? in the glove compartment?
Old 11-14-08, 05:49 AM
Habious
Habious's Avatar
Goes in the trunk. Plugs into the back of the Nav unit with the DVD-ROM drive under the trunk liner.
Old 11-14-08, 02:38 PM
moomoo
moomoo's Avatar
Wow that is really easy then. thanks
BTW for the back up camera, if i use a license plate type camera, what is recommended and where is the best place to drill the hole? or do i have to drill a hole? about the 12V+ where can i tap into that?
Thanks
Old 11-15-08, 07:19 AM
Habious
Habious's Avatar
Thanks
I used a license-plate camera. I go into detail as to where I got it in this thread here...
https://www.clublexus.com/forums/sho...d.php?t=331293
(Page 2, post 17)
I drilled a small hole i the bumper for the wire. it's behind the plate so you can't see it unless there's no plate on the car. Actually, you have to drill a hole in the license plate itself as well as the bumper, to get the wire fed through properly.
You also have to drill a small hole inside the car (the rear "firewall", for lack of a better term)...the back panel of the car, where the spare tire sits.
Old 11-29-08, 09:33 AM
Mangoshot
Mangoshot's Avatar
Default VaisTech & NavTool interfaces with Centrafuse CarPC
I have been reading the dialogue about the VaisTech & NavTool interfaces with Centrafuse CarPC and am impressed with the knowledge base that has allowed me to learn about upgrades to my Lexus SC430. A couple of questions/comments; I understand that the Vaistech includes on-screen software. If so, why use the Centrafuse CarPC system? Also, how much does the NavTool cost?
Lexus SC430, Twilight Amethyst
Old 11-30-08, 03:28 PM
Habious
Habious's Avatar
Mangoshot, I think there might be some confusion on your part.
Vaistech = Allows you to have an auxiliary audio input(s) with the factory stereo
NavTool = Allows you to have an auxiliary video input(s) to the factory navigation screen
The Vaistech and Navtool interfaces don't do anything on their own; they ALLOW you to hook up external devices to the factory audio and video system.
You could hook up a portable DVD player to the audio and video input; this would let you hear the DVD audio through the factory stereo and see the DVD on the navigation screen.
You could hook up a CarPC (running Centrafuse or some other program) to the audio and video inputs and watch movies, listen to mp3's, listen to satellite radio, etc.
But, the Vaistech and Navtool interfaces don't make any sounds/produce any video on their own...they just give you options.
SOME the Vaistech interfaces have on-screen software. The version for the SC430 does not.
The NavTool interface is usually around $200. With the group-buy (see the link in the first post), it could go as low as $135 for the SC430 version, if enough people sign up (right now it looks like it's about $150).
Old 12-08-08, 07:55 PM
ynctypes
ynctypes's Avatar
Habious,
I was looking at the table that came with the navtool package. it looks like one of the wire coming off the unit is suppose to tied to the "hand brake"... the table shows that the dvd video 1 output will activate only if hand brake is applied and the toggle switch is in the right position.
did you tie that wire to the hand brake as instructed or do you just tap it in to some wire that always has 12v? it'd suck if we could only watch dvd while in parked and hand brake is on.
Old 12-09-08, 06:17 AM
Habious
Habious's Avatar
Originally Posted by ynctypes
Habious,
It's been a long time so, the details are a hair foggy. Short answer, yes, I tied this to a permanent spot so it ALWAYS works. However, I thought it was looking for a ground (that's the part I'm fuzzy about).
Since I use the NavTool to display the output of my CarPC, it has to work while the car is in motion.
EDIT: Found the instructions for the NavTool in another thread and it verified what I thought....
"Connect green wire found on the Cardemand unit to the handbrake and 2 white wires to ground. All three wires needed to be grounded in order for Video 1 to be activated. "
Old 12-09-08, 04:11 PM
ynctypes
ynctypes's Avatar
thanks for the response, habious. i am kinda confused about what they mean by connecting the green wire to the "handbrake" then later says it needs to be grounded...
Old 12-10-08, 06:56 AM
Habious
Habious's Avatar
What they WANT you to do is connect it to a contact that is grounded ONLY when the parking brake is applied. That way, you can't switch to the aux video input while you're driving.
Most people just connect it somewhere that's ALWAYS grounded, so you can switch to the aux video input whenever you please.
Old 12-24-08, 09:50 AM
w0ggy
w0ggy's Avatar
In case anyone is interested, there is another groupbuy up for the NavTool:
https://www.clublexus.com/forums/clu...group-buy.html
NavTool
Club Lexus Vendor Marketplace
41
01-15-11 05:24 AM
NavTool
12
07-22-09 10:10 PM
NavTool
06-25-09 07:22 AM
NavTool
37
03-19-09 06:53 PM
NavTool
170
11-17-08 10:16 AM
Quick Reply: NavTool Video Interface Unit Group Buy
