Steering wheel button module
Old Jun 6, 2008 | 10:53 AM
Habious's Avatar
Habious
Default Steering wheel button module
Has anyone removed the button module that's on the side of the steering wheel (volume,channel, etc. buttons)?
If so, how does it come off?
I would like to get access to this is try to tap into the controls for my CarPC but, I don't want to break it trying to get it off. I've tried a little prying and it seems to move but, it won't pop off. I don't want to pry, pop it off, and then discover that it was screwed in from the inside and I've now screwed it up totally!!
I have a CD-Rom of the service manual but, can't find any procedure/maintenance for this particular part.
Anyone?
Old Jun 7, 2008 | 07:07 PM
CAMAracer's Avatar
CAMAracer
Default CD manual
Taking from Chapter 82-2 (cruise control)
There seems to be 3 claws that you can undo with a screwdriver. This will pop off the cover.
PM me if you don't know which section of the manual I'm referring to.
Old Oct 9, 2008 | 10:45 PM
prex's Avatar
prex
Hi - you've probably long since figured out how to pop the cover off (then it unscrews) but at anyrate - very important to note that my experience was that the car's horn was disabled with this module disconnected. It's likely that someone will remove the module for some solder work, etc, go for a drive and maybe find themselves in a dangerous situation.
I found that connecting anything disabled the buttons, so I just drilled one in and stuck the guts of a Griffin AirMate inside soldered to it. Your electronics skills are far beyond mine, so you might figure out something else ...
hope it turned out great,
-b
Old Oct 9, 2008 | 11:20 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Been a while, but if I recall correctly the cover pops off which reveals screws which must be removed.
Spideync
Dec 21, 2017 08:53 AM
SonyHome
Jul 12, 2014 06:24 PM
Tomcio78
Nov 21, 2012 01:08 PM
jewel
Mar 27, 2007 03:34 PM
Lenscap
Oct 10, 2005 06:50 AM
